Results 1 to 15 of 18
Thread: Radiator fans with egnition off?
    Jul 2009
    Van Nuys
    74
    After getting my 91' SC running outstanding I now have this issue that just started today. I had to disconnect the fan motor so my battery wouldn't go dead. I have replaced so many parts so I have no clue what's causing this.
    Can anyone please give me some ideas?
    May 2003
    Robinson, Pennsylvania
    1,122
    when my car did that i noticed the small ground wire from the battery to the fender was loose , i added an extra wire to be sure and never had an issue again
    Madison, Ohio
    17,586
    Bad IRCM is the only thing that can turn the fan on with the key off.
    Email me here.
    Jul 2009
    Van Nuys
    74
    Is the IRCM the box located in front of the air filter?
    Jul 2003
    Eastern (nee Western) PA
    4,993
    Quote Originally Posted by Coroner View Post
    Yes.
    Can you be 100% clear on when the fan runs? Does it run with the car turned off, you standing in front of the hood with the key in your pocket?
    God bless!!!
    Former Birds:
    Jul 2009
    Van Nuys
    74
    Yes.
    Yes. It started doing it when I returned to me car after shopping and noticed the fan was still running by it's self.
    Jul 2003
    4,993
    Gotcha. It wouldn't be the EEC ground, then. I guess the IRCM is the place to look, as Dave suggested. Probably, one of the relays inside welded closed.
    You can get a rebuilt box (expensive) or test and replace specific components yourself if you are comfortable with it. You will have to drill out a couple of rivets to open it.
    God bless!!!
    Former Birds:
    Jul 2009
    Van Nuys
    74
    I had replaced the IRCM with one from the bone yard in an attempt to get the temperature to run with the needle straight up rather then pointing at the M all the time but I remembered to save my original so I switched it back and all is good except for the fact that the temp gauge still remains pointing at the M which I still can't figure out.
    Anyone have any ideas as to what could be done to lower the temperature so the gauge stays straight up instead of pointed to the M?
    Madison, Ohio
    17,586
    The IRCM doesn't dictate the temp the engine runs at, that is determined by the rest of the cooling system and the EEC. If you have changed the thermostat to a lower temperature without also getting a chip to command the fan on at a lower temperature then the engine will run hotter.
    If you haven't done that, then make sure the fan is working on both speeds. 220 deg for the low speed, 228 for the high. The M usually coincides with close to the 228 deg. It could well be that your low speed fan isn't working.
    Otherwise, clogged radiator, leaking headgaskets, air pockets, etc. are all things that can cause a hot running engine. Check the fan operation first.
    Email me here.
    Jan 2010
    Bossier City, LA
    2,232
    Coroner - one thing to keep in mind is that there are TSBs on the sending units being bad.
    Have you queried the ECU to see what temp it thinks you're at? M may be, say, 200F ...
    RwP
    Jul 2009
    Van Nuys
    74
    RwP
    No I haven't. I do have a new fan motor and both speeds do work. Low when the air conditioning is on and high when it get up to full temperature. I installed a while back with a standard thermostat.
    So how do I querie the ECU?
    May 2003
    1,122
    both my sc always ran fairly cool unless a lot of city driving or a bad thermostat or headgasket or clogged radiator
    ny\long island
    2,691
    180 t-stat
    I changed my t-stat in my 93 sc a few months ago (180) so mines is running a lil high now. I was told I need a tune to tell my eec to turn the fans on sooner. where can I get this (tune or chip)........I forgot to ask the guys ,damion dave while I was at carlyles last weekend.
    Jul 2009
    Van Nuys
    74
    Quote Originally Posted by pock1 View Post
    This sounds like just what I need. Anyone know how to do this?
    Jul 2009
    Van Nuys
    74
    So is this even possible????
  1. Radiator Fan doesn't shut off
    By johnwartjr in forum Technical Forum
    Last Post: 05-10-2011, 10:09 PM
  2. wtb radiator fan with motor
    By pipecraze in forum Want to Buy
    Last Post: 09-25-2007, 06:17 PM
  3. swapping out stock radiator fan with low pro fmic fan
    By 8ate8 in forum Technical Forum
    Last Post: 03-13-2006, 06:39 PM
  4. What is the deal with the radiator fans
    By ThunderDave in forum Technical Forum
    Last Post: 02-22-2004, 12:18 PM
  5. ABS Pump runs with key off
    By Don Knapp in forum Technical Forum
    Last Post: 08-13-2002, 10:50 PM
