any ideas??? Help
Greg Coleman
my friend has a 94 he just put in a new battery started it up no problem moved it out of the garage shut it off. He went to restart it and nothing at all no fuel pump prime no click no nothing.Any ideas?????
Greg
Confirm there is over 12 volts between the positive and negative cables.
I can go 8-10 mths on the red car and it won't start the next key turn.
Go out and give the cables a twist and it's good to go.
Doesn't matter how tight I torque them down.
Paul
Check at battery post, at wires terminals and Mega Fuse/Fender relay (can't remember which 94s have). All of this is to check the wire/connections.
If have 12v I'd check ignition switch
