Results 1 to 8 of 8
Thread: swapping a sc motor into a 60s van
    Jun 2014
    1
    I own a 64 econoline and am very much considering putting an sc motor and trans into it, does the sc have a body control.modul and such as tonwhere I'd need to be using the cluster from the bird to make the engine run or is it more like a 5.0 where I wire it and let it fly I wanna know before buying the donor car, any help is welcome
    Aug 2012
    South Dakota, The West Side
    83
    As far as I know there are the following control modules/wiring items if you do a swap.
    IRCM, located behind the passenger side headlight
    EEC Module located under the dash on the passenger side
    Main fuse box mounted on a holder on the battery tray.
    There are other site users who will have quite a bit more knowledge doing these kinds of swaps. This is just to give you an idea of whats going on.
    Sounds like a cool project.
    89 SC-5 Speed - Build in Progress
    Indecision is the key to flexibility, and I am very flexible.
    The beatings will continue until morale improves.
    Jul 2003
    Eastern (nee Western) PA
    4,988
    Quote Originally Posted by falconvan View Post
    You don't have to match the EEC to the cluster or to any special control module. The only exception is that the IRCM does have to match the year (within limits) because the components inside actually changed from year to year, so the EEC inputs would not work on it the same way.
    God bless!!!
    1990 SC auto ... red outside, gray cloth inside ... ~205,000 miles (and climbing) ... driven daily!
    Mar 2010
    Grafton, OHIO
    618
    If you insist on abusing yourself in this manner , You need to do a search for jclars and his "angrybird". He put the ENTIRE deal in a 56 ford p-up.
    He did an awesome job, but had MANY struggles along the way. I would recommend you look at what he did/went thru before tearing into a project like you r thinking.
    Adam
    Oct 2012
    Lynden, WA USA
    207
    HAHA - Adam - abuse indeed. But thanks for the compliments!
    And when it comes time to fit the front buckets on a elevated support stand, you can prolong the abuse as I did this week! The seats bolted into nice little preformed pockets on the dang floor of the T-bird. I think everyone of the support points is at different elevations! But I have a design in hand to pass along when you get to that point!
    But it is all doable! And rewarding when done. Those engines propel these old vehicles quite nicely...(understatement for sure).
    John L.
    Mar 2010
    Grafton, OHIO
    618
    Yeah, John, I've got just the seats with the headrests removed in my '49 F1. I ended up cutting the brackets off and welding tabs onto the adjusters and building a frame out of 1" square tube to raise them to correct position. The up side is it gives you a nice "box" frame for either under seat storage, or a hell of a stereo install!
    Keep on truckin'
    Adam
    Oct 2012
    Lynden, WA USA
    207
    Ditto with the 1" tube frame. My seats are tilted back based on the stock anchor points. Still able to position straight if desired, but it allows the seat (also w/o head rests) to slip just under the rear window brace, gaining about 1" of legroom. Very comfy seats.
    I think we may have scared falconvan and gone off topic at the same time.
    John L.
    May 2013
    60
    I am going to do the same some day with my 63 Falcon wagon.
  1. SC motor into a 83 mustang.
    By bye-bye-birdy in forum Technical Forum
    Last Post: 02-20-2013, 05:10 PM
  2. 95 sc motor swap into existing 94 v8 bird
    By J3ARB3AR in forum Technical Forum
    Last Post: 07-31-2011, 10:27 PM
  3. 95 sc motor into 92 sc
    By Super-chicken in forum Super Coupe Club of New England
    Last Post: 12-22-2009, 01:38 PM
  4. SC motor transplant into Ford Ranger?
    By MTTod in forum Non Technical Forum
    Last Post: 10-08-2003, 08:22 PM
  5. Problems with SC motor swap
    Last Post: 06-05-2002, 01:21 PM
