Page 1 of 3 123 LastLast
Results 1 to 15 of 34
Thread: Cooling fan not going on :( Help!
    Feb 2013
    Allentown, PA
    208
    Ok so yesterday I went to do the #14 wire cut trick on the ICRM because I noticed my car would run too hot in traffic. I cut the wire and then wired in a switch under the dash and went to try it out. I flipped the switch on and off and no fan . I can hear something click when i flip the switch but the fan doesnt want to come on at all. I ran 12v to the fan motor and it started to turn. What could be causing the fan to not work? Could it be the ICRM, a short, a fuse? Idk what to do right now. The car is a 94 so it has a hi and low speed fan. Any help would be greatly appreciated.
    Thanks, Phil
    Roanoke, Virginia
    3,270
    On a few of my '94s I've had an underhood fuse burn up and melt for the fans to fail...others have had the same one let go. Think its a 60amp fuse for low speed...been a while since thats happened.
    Also The Temp Sensor on the front corner of the intake manifold can cause the fans not to work also.
    Just some thoughts.
    -Tim
    Current Collection
    1995 Thunderbird SC - Auto
    1994 Thunderbird SC - 5spd
    ny\long island
    2,679
    cooling fan
    check the temp control on the t-stat.u may need an icrm, theres a few relays in it,
    Feb 2013
    Allentown, PA
    208
    Are the relays just in the fuse box? is there anything to plug or unplug to get the fans to go on all the time? If the wire is cut could it still be the icrm? And would an icrm from a 92 sc fit on mine? My brother has a 92 and if it would work i could test it and see if it is the problem. Kind of a lot of questions i just asked lol
    Feb 2013
    Allentown, PA
    208
    Also i forgot to mention that my ac doesnt work and the fan didnt come on even with the a/c on. I disconnected what i thought was the ecm (tube on intake manifold with sensor on it) hoping the fan would turn on and it didnt. Does this mean its a fuse or wiring issue?
    Roanoke, Virginia
    3,270
    Quote Originally Posted by philstad28 View Post
    Unplug the coolant temp sensor on the intake manifold, passenger side by the oil fill hole...Fan will run on high when the car is started. Also may cause a hard start.
    -Tim
    Current Collection
    Feb 2013
    Allentown, PA
    208
    Is that the one on the tube or is that another one?
    Roanoke, Virginia
    3,270
    Attached a picture with the general location I am talking about. It has the heater hose going into it and has a sensor on the top..
    -Tim
    Current Collection
    Feb 2013
    Allentown, PA
    208
    Ok thanks . I think i pulled that one off and the fan still didnt go on
    Roanoke, Virginia
    3,270
    You have the IRCM wired back to normal or is it still cut...in the factory configuration it should if everything is working properly.
    -Tim
    Current Collection
    Sep 2011
    Las Vegas, NV
    68
    Did you check the fusible link at the solenoid? That is where it acquires 12v, I had a '90 that burned in two at the link. My buddy found it just by chance while I was installing another engine.
    Feb 2013
    Allentown, PA
    208
    I have the ICRM so i could switch it at wire 14 and either way i switched it the fan didnt come on. How do i check the fusible link? Where exactly is it at and what does it look like?
    Sep 2011
    Las Vegas, NV
    68
    I just noticed by Tim's photo your working on a '94. I don't see the solenoid in that photo, my apologies! I was working on a '90 and it is located on the drivers side fenderwell behind the fuse box/battery. I do not own a 94/95 so I am not sure where/if they have that same solenoid. If they do and you find it, the link looks like a thick black wire and is on the powered side of the solenoid.
    Feb 2013
    Allentown, PA
    208
    Its all good thanks for responding . Ill check to see if there is anything that could be a fusable link. What fuse would control the fan?
    Sep 2011
    Las Vegas, NV
    68
    On the early models there is no fuse for the 12v lead to the IRCM, it is protected by that fusible link at the solenoid. I just checked my '90 and the fusible is actually a dark blue color but was so dirty it looked black.
  1. Cooling fan not turning on by itself, help!!
    Last Post: 07-28-2014, 05:35 PM
  2. Cooling fan not coming on. IRCM?
    By rokclimb15 in forum Technical Forum
    Last Post: 11-05-2006, 10:31 PM
  3. Cooling fan not turning on
    By derekhay316 in forum Technical Forum
    Last Post: 10-03-2003, 07:30 PM
  4. Cooling Fan not coming on
    By supercoupe92FL in forum Technical Forum
    Last Post: 06-06-2003, 09:14 AM
  5. Cooling fan not turning on
    Last Post: 06-05-2003, 07:06 PM
