Results 1 to 15 of 18
Thread: Victor HS5816A Gasket Set
    Apr 2014
    48
    What my real question is, is the 3.8L N/A Engine head gasket compatible with our SC 3.8's?
    This is apparently compatible with both our SC's and the regular 3.8 T-Birds.
    Thanks!
    PNW
    6,376
    I'd go Felpro, and if you're doing a build and can properly prep the heads/block consider MLS.
    Apr 2014
    48
    My local parts store can't get Felpro. These are all they can get
    PNW
    6,376
    Tried eBay & Amazon?
    Autozone ships to home in some cases.
    Are you sure it needs head gaskets....
    Sep 2011
    nashville
    346
    I am sure someone will correct me if I am wrong on this. But I am pretty sure it is what I found when doing some digging on the subject.
    There was a local eBay seller that sells new old stock/clearance automotive items. They had a victor Reinz complete set including head bolts for around a $100. Being on a tight budget I snagged it. In digging to find out what head gasket was in the kit and if it would work for me I found that the part numbers have changed over the years. The opposite of what you are thinking has actually happened. The t bird gaskets have become the stock replacement gaskets. Which IIRC is a graphite gasket. The more expensive kits go to newer gasket technology/mls. Therefore find out what gasket is in that kit and cross reference it to see what the gasket really is. Again IIRC Victor Reinz is making only graphite gaskets for the Essex 3.8 in any form. Which would be the "factory" gasket on the SC 3.8.
    As much as I also prefer Fel Pro over anything else sometimes you have to do what you have to do.
    Apr 2014
    48
    Quote Originally Posted by jdsgallops View Post
    Okay, that makes sense. So in conclusion, they work its just that they aren't the long lasting high mileage gaskets that people often strive for in these cars?
    Apr 2014
    48
    There is a pretty strong likely hood that it does not. Im replacing them cause the car is in the garage, having other work done to it before I make it my daily driver again. Minus well replace the HG's while I have another car available before I loose the HG's and dont have another car on hand.
    Sep 2011
    nashville
    346
    The only differences I could find was in material. All bolt and steam holes lined up for me without an issue. It isn't a matter of how long they will last. It is a matter of how good is your tune and right foot from keeping it out of detonation. The better gasket will be more forgiving before it lets go. Which to some people is a better option. Having the gasket as the short fuse can save something else more costly becoming the cause of engine failure. If it is relatively stock and not driven hard there should be little concern.
    Roanoke, Virginia
    3,187
    What parts store are you using where they can't get Felpro Gaskets? Must be a mom n pops location? I always thought the box stores AAP/AZ/OR/NAPA carried them...
    -Tim
    Current Collection
    1995 Thunderbird SC - Auto
    1994 Thunderbird SC - 5spd
    Apr 2014
    48
    -Tim
    yah it is. its just a local parts store and shop. My dad called O'Reilly's out of town, and apparently they cant get them either.... bizzare i know.
    Apr 2014
    48
    Its just got a couple aftermarket mufflers on it. I don't drive it too hard, even though the pedal does meet the floor every once in a while. How many miles have you put on yours? I am going to probably put only 30,000 more miles on this engine, as it is not my original engine. Im going to do a top to bottom rebuild on my original engine before I drop it back in.
    Apr 2014
    48
    Hey check out what I found! Scroll down to see head gasket material... It says Nitroseal? http://www.autozone.com/autozone/par..._378013_15296_
    Mar 2010
    Grafton, OHIO
    622
    local pricing came up at $99. Not bad, but as mentioned above I would not use anything but felpro or MLS. I'm sure you could have them from summit in 3-4 days even if you live WAY out in the sticks
    Also be aware that the head bolts r 1 time use and will need to be replaced and r not included in the set you linked to.
    Adam,
    Apr 2014
    48
    Quote Originally Posted by aroot1 View Post
    Adam,
    Yes. Do u have a link to head bolts by any chance? And no Im not getting ARP's
    PNW
    6,376
    Felpro head bolts: ES72131 (buy two kits to do both sides)
  1. felpro head gasket set part #
    By intercooled89xr in forum Technical Forum
    Last Post: 05-04-2004, 11:54 AM
  2. Intake Gasket Set?
    By poohusker in forum Technical Forum
    Last Post: 04-15-2004, 06:48 PM
  3. best place to get full gasket set, price wise..
    By supercatxr7 in forum Non Technical Forum
    Last Post: 12-19-2002, 02:26 AM
  4. Gasket set
    By Tim Moore in forum Technical Forum
    Last Post: 10-17-2002, 10:01 PM
