Results 16 to 18 of 18
Thread: Victor HS5816A Gasket Set
    Apr 2014
    48
    Felpro head bolts: ES72131 (buy two kits to do both sides)
    Okay, so I ordered the head bolts. Now, I found this torque spec/sequence. I believe this is for a '93. Will it still work for a '95? http://www.sccoa.com/forums/showthre...793#post332793
    So my other question:
    (1) 50 Nm (37 ft. lbs.) = tighten all head bolts to 37 ft-ibs in sequence }
    (2) 60 Nm (45 ft. lbs.) = then tighten all to 45 ft-ibs in sequence ect ect } is this right?
    (3) 70 Nm (52 ft. lbs.)
    (4) 80 Nm (59 ft. lbs.)
    Sep 2011
    nashville
    346
    I only have about 2 miles on it. After I got it back together I found the water pump seeping. I put replacing it off till I had some of the other issues resolved. I should have it replaced along with the rack and pinion sometime this week. Then I need to get with Dave for a tune before I can put any serious miles on it. It has way more than just mufflers though and I don't drive my cars easily. The kit I got had head bolts with it. See if it is still available. Should be same part number with a -x ending.
    Apr 2014
    48
    okay I ordered them. I found this: http://www.sccoa.com/forums/showthre...793#post332793
    It says its for a 93, but will it still work for my 95?
    Also:
    (1) 50 Nm (37 ft. lbs.) = does this mean to tighten all the bolts to 37ft-ibs in sequence
    (2) 60 Nm (45 ft. lbs.) = then go to 45 in sequence ect?
    Thanks!
  1. felpro head gasket set part #
    By intercooled89xr in forum Technical Forum
    Last Post: 05-04-2004, 11:54 AM
  2. Intake Gasket Set?
    By poohusker in forum Technical Forum
    Last Post: 04-15-2004, 06:48 PM
  3. best place to get full gasket set, price wise..
    By supercatxr7 in forum Non Technical Forum
    Last Post: 12-19-2002, 02:26 AM
  4. Gasket set
    By Tim Moore in forum Technical Forum
    Last Post: 10-17-2002, 10:01 PM
