Results 1 to 6 of 6
Thread: little studder and check engine light
    Aug 2012
    168
    Unhappy little studder and check engine light
    Ok so i have a 90 auto and im swapping to a 5sp i swopped out the auto harness and put in the 5sp harness clutch peddle etc. I havent put the trans in yet just wanted to start it up to make sure everything was hooked up right. Starts up but when i let the clutch out it dies. But if i umplug the trans harness i can let go of the clutch it stays running. But check engin light is on and a slight studder if i punch it. Is this going on because the 5spharness is not plugged in or do i need to throw in the 5sp computer ad well.
    Madison, Ohio
    17,574
    How did you connect in the clutch switch? Did your car have the plug in it like others have suggested? Or did you swap the dash harness?
    Email me here.
    Aug 2012
    168
    I swapped the whole dash harness out. The auto trans is still in it ubtill tonight
    Madison, Ohio
    17,574
    Ok, that explains. The two circuits are conflicting. It will be fine with the auto EEC once you get the transmission swapped.
    Email me here.
    Madison, Ohio
    17,574
    What code have you gotten?
    Email me here.
    Aug 2012
    168
    NOt sure what the code was. It turned on within 5sec. Ifiguard it would be fine after i put the other trans in. Hopfully this weekend it will be in
  1. RPM tach and check engine light
    By nick2003 in forum Super Coupe Club of Ontario
    Last Post: 03-10-2005, 01:28 AM
  2. "Check Engine Light" - sputter and stall
    By pops90sc in forum Technical Forum
    Last Post: 11-25-2003, 10:13 AM
  3. Check engine light and cruise control
    By tigerknight in forum Technical Forum
    Last Post: 01-30-2003, 07:28 AM
  4. Tach 0's and check engine light comes on>>??
    By blk93sc in forum Technical Forum
    Last Post: 11-20-2002, 02:53 AM
  5. help!!! check engine light and no brakes
    By tondog in forum Technical Forum
    Last Post: 08-06-2002, 09:26 PM
