Results 1 to 7 of 7
Thread: Power Window Speed
    PNW
    6,518
    Power Window Speed
    So both of the motors in my power windows are in great shape and the tracks are lubed and I can't find anything binding or worn, etc. but why is my driver's side window not as fast as the pass. side - this isn't normal, right?
    Feb 2011
    642
    KMT it could be the power motor on the slower side is worn if all else checks out.
    I replaced both window motors in my 95 about 2 years ago with New units and they are both very quick going up and down.
    PNW
    6,518
    Yeah, thanks but it's new less than a month. The top center stabilizer was really tight, but backing it off a bit didn't change anything. Pretty weird. Maybe I'll just replace the whole door
    Aug 2011
    Eden Prairie Mn
    106
    Dumb question, but did you check voltage and grounds. On my anny it ran slow and it was the ground. On the 89sc it was the switch not allowing full voltage. Corrected groung on anny and replaced switch on 89. Fixed both.
    Sep 2006
    New Braunfels,Texas
    548
    Mine did the same thing...The felt that is in the rubber channel that the window rides up and down in is worn away...I replaced it and all is well....The channel was applying to much friction to the glass and was slowing it down....
    PNW
    6,518
    Quote Originally Posted by ecyrbh View Post
    Mine does the same thing...The felt that is in the rubber channel that the window rides up and down in is worn away...I replaced it and all is well....The channel was applying to much friction to the glass and was slowing in down...
    I've swapped out the rear vertical channel in the past, but I'll revisit it, thanks.
    PNW
    6,518
    Quote Originally Posted by 69Mach1 View Post
    Ah...switch - interesting. I've had to rework the driver's side, but it might help to swap it out if I can find my spares
    I've added one-touch to both sides, but I haven't sniffed the grounds, so I'll try that, thanks.
  1. power window motor
    By danekejt in forum Non Technical Forum
    Last Post: 06-11-2004, 05:21 PM
  2. Power window fix
    By Katoom in forum Technical Forum
    Last Post: 08-15-2002, 07:35 AM
  3. Power window motors.
    By Renob in forum Technical Forum
    Last Post: 07-22-2002, 01:36 AM
  4. need help with power windows
    By DUKSRULE in forum Technical Forum
    Last Post: 07-18-2002, 05:37 PM
  5. HELP!!!!!!!!! Power Window Motor
    By Les Borda in forum Super Coupe Club of Ontario
    Last Post: 05-28-2002, 05:43 PM
