Results 1 to 4 of 4
Thread: Removing rear springs
    Aug 2010
    Pennsylvania
    91
    Hey guys, I'm in the process of cutting my springs and I cannot get the two bolts out of the knuckles on the LCAs to swing it out of the way. Is it possible to just lower the LCA still attached to the knuckle without damaging the axle or any other components? It will move if I push down on it, I just don't want to break anything.
    Apr 2003
    Ventura, CA
    1,780
    Assuming you have stock springs, I don't think you'll be able to get the amount of deflection you need to make that possible.
    You may be able to remove the halfshaft retaining nut and push it in enough to get it out of the knuckle. I think I've heard that's possible, but I've never been able to make it work.
    Why can't you get the bolts out of the knuckles? Rust?
    Aug 2010
    Pennsylvania
    91
    Yeah they're just seriously rusted in place. Do you think I could take the inboard bolts out of the LCA?
    Apr 2003
    Ventura, CA
    1,780
    Quote Originally Posted by AJMgearhead View Post
    Sort of depends on how rusty they are. Wouldn't be ideal, and it might make getting the LCAs back in a bit of a trick, lining them up with spring pressure on them.
  1. Removing rear coil springs
    By Dahoopd in forum Technical Forum
    Last Post: 09-29-2008, 03:39 PM
  2. Rear Spring Removal....
    Last Post: 04-09-2006, 08:46 PM
  3. Rear spring removal
    By justin07 in forum Technical Forum
    Last Post: 09-30-2003, 04:36 PM
  4. rear spring rubbers
    By ChrisPearl95 in forum Non Technical Forum
    Last Post: 03-07-2003, 12:04 PM
  5. Air Bags in rear springs
    Last Post: 12-07-2002, 08:07 PM
