Results 1 to 14 of 14
Thread: verry hard to start warm.
    Aug 2012
    167
    Ok so i suvessfully swapped my 90 auto to a 5sp. I used a 90 5sp dash harness. Runs fine but have a chech engine light on and if i start it back up when its warm it cranks for a while and after a whill will start. When u first start up cold or halfway warm the rpm shoots up to atleast 1,500 then drops down. What sensor could this be. Or could it be less weight to turn flywheel without the torque converter. I was gonna try and lower the idle with the screw on the tb.
    PNW
    6,402
    Could be an O2 sensor...or not Are they both still connected after the swap?
    Did you check the codes yet?
    Aug 2012
    167
    They should be. I never unhooked them last time i had one unhooked it started right uo
    Aug 2012
    167
    Not sure what code yet dosent the engine have to be at normal temp to check code. Thats what the manual said i think
    PNW
    6,402
    It doesn't have to be warmed up to check for 'C' ~ continuous/stored codes.
    See http://www.njtacc.com/tech/eec_codes.html
    Aug 2012
    167
    Manifold absolute pressure out of range, coolent temp open circuit open, tps out of range high, air charge temp circute open, clutch switch open, fuel pump circuit open. Thoes were with key on and engine off. Didnt flash while running. Clutch switch works tho. But i didnt change the computer behind the glove box when i did the swap.
    PNW
    6,402
    Off hand, I'd say those point to a disconnected harness or two...and/or grounds....or blown/wrong EEC?
    Ottawa Canada
    1,462
    5 Speeds and Autoboxes do not use the same EEC. Guessing most of your issues are coming from that.
    Cheers
    Aug 2012
    167
    That was what i was thinking. But i was told that since the auto runs off of throttle linkage its not controllef by the computer. But i think the computer has to know the clutch stuff. I may have to try the computer swapp. Cause it worked fine till the harness swapp.
    PNW
    6,402
    Do you have a stick EEC yet?
    Aug 2012
    167
    No not yet i got a parts car pulled a bunch of stuff but forgot the computer. I can get it out of the car sat i think. So their diffrent from auto to 5sp in 90?
    PNW
    6,402
    I'm told they are different.
    See this link for part numbers?
    http://www.sccoa.com/forums/showthre...395#post291395
    Ottawa Canada
    1,462
    Check RockAuto.com one for an auto different part number for a stick.
    Feb 2011
    642
    Quote Originally Posted by kw90supercoupe View Post
    Perhaps your problem is in the ECM.
    I have a 5 speed ECM out of a 1990 if you think that's the problem.
  1. Hard To Start Bird
    By Crunchee in forum Technical Forum
    Last Post: 11-21-2003, 08:39 AM
  2. Hard to start when warm
    By 92SCDoughboy in forum Technical Forum
    Last Post: 03-18-2003, 09:24 AM
  3. car runs with no tach indicating...and was hard to start...
    By vettewars in forum Technical Forum
    Last Post: 11-18-2002, 09:25 PM
  4. DIS, Cam/Crank Sensor? HARD TO START
    By Supercrown in forum Technical Forum
    Last Post: 09-26-2002, 03:51 PM
