Results 1 to 12 of 12
Thread: 95 brake master cylinder removal and install help
    Apr 2014
    nw florida
    4
    I need to replace my master and I'm really interested to hear tips and options in doing so....thanks in advance also its abs 2port
    Ottawa Canada
    1,462
    Just a small tip, get a Haynes Manual for Thunderbird 89-97 or Chiltons, they are a big help.
    Feb 2011
    642
    Quote Originally Posted by Subliminal Trix View Post
    I have done this at least twice, best advice I could give you is :
    1. PB Blast the lines and nuts @ the Master, give it time to soak in.
    2. Use a Line Wrench on the brake lines and BE CAREFULL, sometimes they like to twist and kink.
    3. the 2 nuts holding the master to the booster are a no brainer.
    4. BENCH BLEED the master BEFORE putting it back on, this will save you a lot bleeding of the brake system later on.
    By the way, the ONLY service manual worth a darn on these cars is the Ford Factory manual that can be bought on Ebay.
    Ottawa Canada
    1,462
    Agreed the Haynes one stinks I'm sorry I got it from Amazon. I am certain it has less information in it now that I have needed it than the version i had back in early 2000.
    Apr 2014
    nw florida
    4
    I bench bleed the system and everything seems fine until the car starts then the pedal goes to the floor without touching it...bad booster?
    Jul 2003
    Eastern (nee Western) PA
    4,993
    I think there is a valve on the back side of the booster called an air inlet valve. Sounds like it is not working properly. (If I just made this up and anyone knows better, please correct me! )
    God bless!!!
    Former Birds:
    Jul 2003
    4,993
    I just re-read your post and it has me wondering - after bench bleeding the MC, did you bleed the system on the car at all? I can imagine there might be air in there, unless you capped everything tightly while the MC was out.
    God bless!!!
    Former Birds:
    Feb 2011
    642
    Its not the booster, usually when they go bad you have no power assist at all.
    Check the valve at the booster, that is more likely the problem.
    Hey just noticed you in NW Florida, where exactly you located ?
    I am in Cantonment.
    Jul 2003
    4,993
    Quote Originally Posted by 1994blkbirdsc View Post
    Usually, but not always. What if the diaphragm is still fine but the booster hub is cracked, or there is a problem with the internal valves?
    But I think the line bleeding question needs to be addressed.
    God bless!!!
    Former Birds:
    Apr 2014
    nw florida
    4
    Yes I bled the entire brake system...I have found the issue and it was the check valve...thanks guys for all the advice
    Apr 2014
    nw florida
    4
    I am in Cantonment.
    I'm in pensacola...so very close to you
    Feb 2011
    642
    Cool we should get together and talk cars. may be go cruising
    Angelo.
  1. Clutch Master Cylinder Removal
    By iaragon in forum Technical Forum
    Last Post: 06-12-2013, 03:57 PM
  2. How do I remove my brake master cylinder?
    By iwannanSC in forum Technical Forum
    Last Post: 01-28-2004, 10:16 PM
  3. brake master cylinder help (brake lines)
    By HappyHourHero in forum Technical Forum
    Last Post: 09-16-2003, 03:13 PM
  4. Clutch Master Cylinder/Brake Master Cylinder failure?
    Last Post: 06-06-2002, 01:24 PM
