Results 1 to 13 of 13
Thread: 90 Fuel Tank feed and return line
    Ottawa Canada
    1,462
    Can't remember again, are these two lines held in place with the push on connectors with the little black locking clips like the fuel filter, or are they gear clamped on?
    Yup guess who gets to drop by sons fuel tank tomorrow( with him) and drop in the 190 fuel pump...
    Apr 2010
    SLO County
    358
    push connectors most like the one where the fuel lines meet the fuel rail in the engine compartment. They have internal spring clips. So you will need the special tool.
    Ottawa Canada
    1,462
    Quote Originally Posted by gr8ghost View Post
    I'll be damned...ok I have the set for A/C lines and fuel lines, thanks
    Nov 2005
    Fort Wayne, Indiana
    2,989
    Wrong, they are plastic clip retainers. You probably figured that out by now though. There are certain years where one side of the fuel filter requires a fuel line disconnect tool though. 91-93. One of those years.
    Chris
    Sep 2002
    SE CT
    728
    IIRC both my '90 and '93 fuel filter connectors one side was a spring lock and the other used the plastic 'Duck Bill' retainer.
    MikeH
    Salem OR
    7,265
    My '90 SC fuel filter; pull clip, both.
    Ottawa Canada
    1,462
    Uh guys, my question was about the feed and return line on the tank, not the fuel filter LOL
    Have not dropped the tank yet, got sick as dog with some damned bronchial virus and I was write off after Saturday until pretty much today.
    Salem OR
    7,265
    I thought that was answered, sorry. Use the ford style spring release tools. Otherwise, I think you're familiar with thread drift
    Did you get the fuel pump and injectors sorted yet?
    Sep 2002
    SE CT
    728
    The return line is a low pressure line. If the pic I was looking at is correct, they are both duck bill clips. Black=Vent, white =pressure.
    That reminds me, I need to replace the pressure line with a larger one to feed the BBF the convert the old pressure line to the return. Just something else to do.........
    Ottawa Canada
    1,462
    Quote Originally Posted by talonhead View Post
    As in similar to the ones on fuel filter yes? I can't seem to glean that out of the Ford bible it must be there somewhere and it could be wrong.
    Digging back when I did my 90XR7 I don't recall using the spring release tool, maybe in newer years they went to that. Either way I do have the spring release tools.
    Ottawa Canada
    1,462
    Heck no, got sick as dog and by late Saturday I was done. Managed to get his SCP cold air intake on, the one with the box around it, rather shoddy coming from Bill, not impressed but I bought it used from Dave D.
    This afternoon got the raised top on and sealed YAY
    Tomorrow maybe the TB, tank on the weekend.
    THEN I tackle the tear down to the intake manifold and injectors, and to be honest...nervous..it's been some time since I pulled blower off down to the intake manifold.
    Lakeville, MN
    13,517
    Quote Originally Posted by Les Borda View Post
    Meh, it is super simple. Shockingly so once you do it a few times. pop the belt, pull the top off with the top intercooler line. pull the intake hose off the throttle body. Unbolt the cable bracket from the inlet plenum. Disconnect vac lines you can reach, take the 3 bolts off holding the blower down. Remove the cross over tube coupling. Lift it off.
    Changing the spark plugs is brain surgery compared to pulling the blower off.
    Ottawa Canada
    1,462
    Thanks Mike.
    I used to do it with my fricking eyes closed in no time, just been 10 years I bet since I have. I did it like you popped it off at the rubber crossover tube
  1. Removing 90 Fuel Tank
    By Les Borda in forum Technical Forum
    Last Post: 07-27-2014, 06:36 AM
  2. 93-95 fuel tank and a driver seat
    By Rubymustang in forum Want to Buy
    Last Post: 02-05-2007, 07:24 PM
  3. I need fuel tank straps, bolts and clips
    By vytas in forum Super Coupe Club of Ontario
    Last Post: 06-21-2006, 03:27 PM
  4. Braided Steel Fuel Line and Connection to Fuel Tank
    By RussellR in forum Technical Forum
    Last Post: 11-06-2004, 12:57 AM
  5. Fuel Pump,Fuel tank, and Exhaust Questions
    By joshbea6 in forum Technical Forum
    Last Post: 01-08-2003, 02:58 PM
