Results 1 to 15 of 18
Thread: Speedomeer help?
    Jun 2013
    97
    Speedomeer help?
    When I traded the 92 sc for a 94 F150, the speedometer didn't work. Replaced the speedo for a 145 MPH unit and gears with the better ones from Bill Evanoff. Still doesn't work. 92 M5R2 is in need of a rebuild, so I got a used 94/95 M5R2 from Ryan at the sc shop, and had it put in. I was hoping the speedometer, and odo might work. They don't.
    My question is: What is the usual cause of failure? The sensor in the trans, or maybe the schematic on the back of the gauges, or something else? Does the 95 M5R2 trans work with the 145 MPH speedo? I have tried 3 different gauge clusters, with the same results.
    Thank you,
    Jim JOHN 3:16
    Feb 2013
    Custar, Ohio
    152
    sounds like the speed sensor in the tail of the trans is bad
    Jul 2003
    Eastern (nee Western) PA
    4,993
    Quote Originally Posted by 90tbird4.7l View Post
    Quite probable.
    Or the gear on the end of it could be worn out.
    Or a loose / corroded plug under the car.
    Does cruise control work?
    God bless!!!
    Former Birds:
    Jun 2013
    97
    speedometer help?
    Quite probable.
    No. Cruise never worked either.
    Jul 2003
    4,993
    If cruise never worked, then I think it's probably the VSS or wiring. I would look at the plug on it and go from there. The VSS is not hard to remove from the trans.
    God bless!!!
    Former Birds:
    Jun 2013
    97
    speedometer help?
    What is the vss? Where is it located exactly?
    Thank you,
    Jim JOHN 3: 16
    Jul 2003
    4,993
    The vehicle speed sensor bolts into the side of the transmission, near the back. There's a plastic gear on the end that meshes with a metal gear inside the transmission.
    This page shows an auto, but manual should be similar.
    http://www.justanswer.com/ford/3boct...sensor-v6.html
    God bless!!!
    Former Birds:
    Jun 2013
    97
    speedometer help?
    Where can I get a new sensor for the 95 m5r2?
    Thank you,
    Jim JOHN 3:16
    Jul 2003
    4,993
    The normal parts stores should be able to get them. It's a common sensor.
    http://shop.advanceautoparts.com/p/b...+speed+sensor#
    P.S. - I would look it over before ordering one. Maybe you need a gear, which is not included with a new sensor. Or maybe it's just unplugged, or a wire got pinched.
    God bless!!!
    Former Birds:
    Ottawa Canada
    1,462
    FYI they size that gear by diff ratio so speedo is on track.
    Jun 2013
    97
    speedometer help?
    Quote Originally Posted by Les Borda View Post
    What gear ratio does the 92 sc have? 2.73:1? Or is there a tag on the dif. cover that would tell me?
    Thank you,
    Jim JOHN 3:16
    Ottawa Canada
    1,462
    I think there is supposed to be a tag on the diff cover. I didn't know they still did 2:73's in 92 my 90 XR7 had that ratio.
    Salem OR
    7,507
    You should be able to decode the axle ratio from the door tag (assuming it hasn't been changed out, etc.). See: http://www.35thatr.org/VINCodes/tb_ax.htm
    Ottawa Canada
    1,462
    smart azz..
    Dec 2016
    Dallas
    120
    Speedometer not working
    I have a similar situation. My odometer is working but the speedometer is not working. Today I replaced the VSS, it is located in the rear part of the transmission on the driver side. Is there a way to test the cable? Probably lifting the rear tires and running the engine, I am looking for troubleshooting options.
    Thanks
  1. Invoking all SC Gurus. Can you help me?
    By wickedSC in forum Non Technical Forum
    Last Post: 05-28-2002, 08:24 PM
  2. Need Best prices on some ford parts - please help
    By white91sc in forum Non Technical Forum
    Last Post: 05-27-2002, 09:53 PM
  3. Someone with carfax...help
    By tealsc in forum Non Technical Forum
    Last Post: 05-21-2002, 05:30 PM
  4. TBKHomeworld I need your help!!! anyone thats removed 5spd
    By 89xr7man in forum Non Technical Forum
    Last Post: 05-15-2002, 12:40 PM
  5. help, power steering pulley
    By eds94tbirdsc in forum Non Technical Forum
    Last Post: 05-14-2002, 12:10 AM
