Page 4 of 5 FirstFirst 12345 LastLast
Results 46 to 60 of 65
Thread: New to me 1994 SC 5 speed...Teal v2.0 :)
  1. #46
    May 2011
    825
    Wow! That's what I call rusty. I sure am glad I have a southern Cali car. My brake and fuel lines have some rust, but look brand new compared to what you cut out. Looks like you are on the correct path though my friend.
  2. #47
    SCCoA Member#1257
    3,297
    Very slow progress but yesterday I was able to bend new lines and flare all ends. Just need the union fittings so I can finis the patches and start the bleeding process. Hope to have this done soon.
  3. #48
    SCCoA Member#1257
    3,297
    New sections of brake line are in! But after all this I wondered...did I need teflon in the fitting threads?? All that's left is fiddle with the mounting and add some rubber insulation so the lines/fittings don't rub against each other and the car surfaces....then bleed and hopefully all done!
    By the by....some experience with brake line fittings from Autozone. I ended up buying different brands of fittings because I couldn't get all 4 from the same store. I would stay away from the Dorman brand. When I tried to tighten the lines with the Dorman unions the material was so soft it would strip easily and would not tighten. I had to go back to the store and get two more of the AGS fittings. I can't really say its a "China" thing because both fittings are made in CHina...maybe Dorman is more chinese than AGS? . Caveat emptor!
  4. #49
    SCCoA Member#1257
    3,297
    Lines in, brakes bled...but when I tried to start the car to check for leaks i had the annoying no-start condition I posted about earlier. Talk about buzz kill...i thought I would get to drive her today, but alas...denied!
    Anywho, the Motive bleeder worked amazing and I documented the procedure to bleed the Teves IV abs valves. NOTE: The video only shows me pushing the "Valve" button a few times but it has to be held down for about 20 seconds. I retried the procedure after the video was recorded and followed the correct steps.
    I did the valve bleed about 3 times because after each try and after syphoning out the old fluid from the reservoir I kept seeing these little specs. Little vacuum pump worked like a charm and helped keep things clean.
  5. #50
    SCCoA Member#1257
    3,297
  6. #51
    SCCoA Member#1257
    3,297
    So the good news....the random no-start problem appears to have been fixed with a new ignition switch.
    The bad news...after finally starting the car after doing the brake line repairs....brake pedal still smushy...so gotta re-bleed.
  7. #52
    SCCoA Member#1257
    3,297
    back on the road! Been driving it for a couple days..brakes feel good, no starting issues. Enjoying it thoroughly!
  8. #53
    SCCoA Member#1257
    3,297
    Car was on a short vacay for a few weeks. Started it up today to drive it this week and saw this. Looks like I gotta start hunting the leak. Or it may be the seal around the air inlet in the pass side.
    Gratuitous pic of the noble beast from her current parking spot:
  9. #54
    SCCoA Member#1257
    3,297
    Not much update from my end. Still haven't fixed the power locks that went wonky on me but I live with it for the few weeks that I get to drive the car. All else going OK with the beast.
    Took this cool pic last week when we got some fog.
  10. #55
    Nov 2016
    254
    Thank you sir for the great post. Have learned much.
    Cool photo !!
    Creighton
  11. #56
    SCCoA Member#1257
    3,297
    Quick update front my end. Power steering on the teal car went Kaput early in the year. Took my time diagnosing and finally doing the work. Lots was done in the process:
    *added missing studs to steering bracket for lower and upper IC tubes. Lotsa people leave these out but...for originality purposes...I did the contrary .
    *Took the entire steering bracket out and did some cleaning back there
    *added anti-seize to all the bolts that were removed/re-installed
    *added missing clips at the bottom of the intercooler that attach it to the shroud
    *added the reusable thick teflon gaskets to all corners of the IC tools. I also painted the gaskets ford grey to match the intercoolers slightly instead of being all white.
    *cleaned up all the steering fluid gunk that had accumulated due to my slow leak from the EVO valve (in retrospect, this is what probaly killed my pump)
    *replaced steering pump with new Motorcraft refurbed unit. Oddly enough, the pumpt that came out appears to also have been a motorcraft refurbed unit. Flushed fluid thoroughly with cheap autozone fluid, then refilled one last time with good red Motorcraft Type F/Steering fluid.
  12. #57
    SCCoA Member#1257
    3,297
    *While doing the fluid drain at the steering fluid cooler I knocked off the plastic radiator drain plug. The thing was so stripped I'm surprised it was still attached. This forced me to do a full coolant flush. I was not able to source a replacement plastic plug so I just used a zinc plated m12x1.25 with pilot tip and gasket. Fit perfectly, no leaks.
    The clincher....I finish the work, do a test drive, clean up the trunk of tools and junk and get it ready so I can drive it to work the next day. Get in the car the next morning, start driving off and.....squishy brake pedal. Looks like fluid leak in the passingere rear somewhere. So, that's the next thing to tackle on this basterd. I do miss it tho...the drive to the car felt pretty good.
  13. #58
    SCCoA Member#1257
    3,297
    And we're back on the road!!!
    Patched the leaky brake line. It ended up being the line to the passenger side rear tire. One of the plastic line retainers right above the differential was rubbing against the line until it developed a pinhole leak. New line, fittings, fluid and bleed and we're back in action!
    Steering job and brake line job seem to be working fine.
  14. #59
    SCCoA Member#1257
    3,297
    I was trying to catch it last week when it hit 190k, but missed it!
  15. #60
    SCCoA Member#1257
    3,297
    Teal car got a new radiator a couple weeks ago. This all stems from the Chameleon car needing a rad due to small leak, but the Teal car gets a lot more use so it got a new rad, and the old rad will go in the chameleon car after a good refresh.
    I was just able to finish the Teal's rad job tonight due to time constraints and I was waiting for a suitable drain valve to use instead of the stoopid plastic drain plugs. While doing the job I was pleasantly surprised that belts and hoses were all OEM Motorcraft, and in very good shape. Even OEM hose clamps! I decided to remove the belts and hoses and save them for the future. The job turned into:
    *new Spectra premium radiator PN: CU1879
    *new Stainless Steel bolts and washers for the intercooler bracket attached to the rad (now properly coated with anti-seize)
    *Painted intercooler bracket and uber cleaned and conditioned the shroud
    *new upper and lower rad hoses- I opted for Continental brand hoses since Continentals are the old Goodyear brand, great quality
    *new coolant bypass hose at the thermostat housing - best one available is Gates, I also bought the Dayco but the Gates rubber is better quality
    *new belts all around - Also opted for Continental Elite Poly V which are the old Goodyear Gatorbacks
    *new Motorcraft rad cap
    *new billet purge bolt and stainless steel cap (thanks to TBirdSC shop!)
    *painted OEM hose clamps
    *painted clip holding hose to the coolant reservoir
    *did tons of cleaning in the rad support and subframe
    *new EZ drain valve in the correct size for the Spectra rad. I opted for this since I could not find a cheap plastic drain petcock for the drain size in this radiator. I plan to keep up with fluid flushes so I need a good, clean way of draining the coolant.
    *Fresh Motorcraft coolant
    On to the pix!
    OEM clamps for the coolant bypass hose
    Different bypass hoses. OEM motorcraft at the top. The two bottom ones are Gates brand. I found two different part numbers. They look a bit different, but both work perfectly. I opted for using the next-to-last one. The rubber from the Dayco brand was way softer than the Gates brand.
    Main serpentine belt was Dayco, but supercharger & jackshaft belts were OEM Motorcraft
    Replacement belts
    New Rad
    Clean shroud
    Rad cap
  1. Electrical gremlins on new to me 92 SC
    By peagnit2 in forum Technical Forum
    Last Post: 07-09-2013, 01:36 PM
  2. New to me 92 sc
    By davec73 in forum Non Technical Forum
    Last Post: 10-18-2011, 08:02 PM
  3. new to me 92 sc
    By ghostryder in forum New SC Owner Forum
    Last Post: 07-21-2011, 03:14 PM
  4. New to me 89 5 speed sc
    By davec73 in forum New SC Owner Forum
    Last Post: 03-29-2011, 09:52 AM
  5. New to me 89 5 speed sc
    Last Post: 03-23-2011, 10:18 PM
