DriftingThunder
FOR SALE Moonlight Blue 1994 SC 5-speed. The car has 210,000 estimated miles (the odometer quit at 196399).
I wanted to keep this as a parts car. It's perfect for that, for me, seeing as to how my other SC is also a blue '94 5-speed. However, I have nowhere to store it anymore, and it has to go, hopefully before the snow gets here this year.
Goods;
B&M Ripper Shifter
Walbro 255 lph fuel pump
MAC Cold air intake kit, also has a MP heat shroud
75mm throttle body
early SC blower pulley (3% od on late model?)
Replaced upper & lower front control arms
Replaced both strut rod bushings
Solid rubber engine and transmission mounts
Urethane rear shock bushings
Urethane differential bushings
Gator back belts
Teflon IC gaskets
Amplifier bypass harness to run radio direct to speakers
Blaupunkt rear 5x7 speakers
X-site 5x7 front speakers
Recent coolant and thermostat change
Doesn’t burn oil or coolant
Drives good and straight. Engine still strong
E-brake works but needs adjusted
Heater controls and AC still works
All other controls work fine (locks, mirrors, windows, lights, seats …etc)
Bads;
blown headgasket
I removed the front bumper and probably going to remove the front fenders
The odometer gear is toast
The body is really getting pretty rusty, it's not a looker anymore
Various paint chips and clear coat spots
battery doesn't hold charge well
interior isn't in great shape, but some of it is still good; full leather, grey
Attached pic is the only pic I have now, but I can take more. Keep in mind it does not have a front bumper cover anymore.
Must sell whole. Located in Osceola, IN 46561. Asking $900 obo
Thanks.
Goods;
B&M Ripper Shifter
75mm throttle body
Gator back belts
Teflon IC gaskets
Bads;
blown headgasket
Thanks.
