LAST CHANCE! misc parts delivered to shootout! *Added new parts including shortblock*
Jacob_Royer
%^%^%^%^%^%^%^%^%^%^%NEW STUFF%^%^%^%^%^%^%^%
Early blower cases good shape $25 each
Chrome fuel rail $25
Remote mount tranny filter kit $15 *SOLD*
Washer tank late style $10
Maf sensors $5
Coil packs $20 each
Injector harness $10
Early brake resivor $5
Overflow tanks $10 each
Oil cooler $15
Starter $25
Never used spare $10
*Early short block 15k mile stock rebuild Has .032 deck clearance do to rod reconditioning so may want to shave a little off the heads to bring the compression up OR ideal for a turbo build. Reconditioned rods and crank Speedpro pistons new cam bearings .030 over $350 delievered to the shootout (Sale pending)
*Front door seals $10
*89/93 side mouldings (-driver side door trim) $10
*Multifunction switch $30
*lower dash trim with vents that the HVAC controls and cd player go in $20 black
*Black rear speaker covers $10
*Tailights both sides for $40
Stock Sc crankshaft needs ground spun #3 bearing $25 (Pending)
Red gfx $50
Door glass eiather side $30
Sc oil pan $25
Seat belt control module $15
Sc intake manifold $15
Hood latch assembly $5
PP 75mm tb with electronics $75 *SOLD*
80mm mustang maf $20
Stock Sc maf large or small $5 each
Top and upper IC tube.black w/polished letters $30
Aod dipstick $20
Stock fan $45
Early valve covers $10
Oxford white driver side fender no rust good shape $30
1990 owners manual with factory binder $5
Gauge bezel non auto headlight $20
Early inlet plenum $10
Return plenum $10
IC pipes upper or lower $10 each
Factory head unit 93 NOT jbl tape deck $25
*Black Sail Panels 89/93 $40
*Upper windshield Trim amd Rear upper trim good shape but needs re-coated $20 for both
*93 style Cowl panels one crack driverside easy repair $10
All prices are delivered to the shootout and must be pre paid .
I will take the crank Jacob. I just need to get to the Dr. Tomorrow to see what he has in store for me. From there I can make plans to come up and snag it. Probably not going to make the shootout with everything else going on around here right now.
Maf sensors $5
Coil packs $20 each
Oil cooler $15
Starter $25
Last chance i'm loaded up and will be working 3rd shift thursday night and going from work to the shootout. Let me know if you want anything before thursday evening so i can load it up! shoot me an offer i want this stuff out of my way!
