There was a lot going on in the Trailerhood today so I could only run two tests. But, another member thinks the engine isn't trashed. I'm inclined to believe that. But there's still something seriously off here.
Vacuum at idle is 10" and hits 20" during the test.
The first test gave me codes as follows.
41
33
72
73
25
74
And Cylinder balance.
50
60
The second test gave all the same codes but the balance test added a fail in cyl 3.
The EGR codes I expected, there isn't one.
The Brake circuit code is because a line ruptured.
I'm going to clear the codes and run 3 KOEO and 3 KOER tests tomorrow after work.
It's going to be nice this weekend so I'll do the compression tests Sat and Sun.
Any thoughts would be appreciated.
Thanks!
41
33
72
73
25
74
50
60
Thanks!
