Page 1 of 9 12345 ... LastLast
Results 1 to 15 of 123
Thread: 93 SC Build Thread
    Aug 2005
    Paoli Indiana
    4,563
    93 SC Build Thread
    First off i scored a new blower!
    And i finally finished a raised top for MY car
    And after i purchased a parts car with lots of goodies i sold my current long block and its now going to bring life to a really nice low mile black on black 92 that Mike Inch purchased off of ebay.
    The new setup will consist of the following
    NEW 94/95 short block
    Ported Heads Welded Heads w/1.86/1.60 stainless undercut valves Titanium retainers, LS1 beahive springs
    Roller Rockers
    .605 lift cam
    ARP head Studs
    MLS Gaskets
    MPX
    MP Springs
    MP 15% od 10 rib setup
    3.5" Slot Maf
    MP 85mm tb
    255lph Walbro
    Fuel Pump relay kit
    #80 Injectors
    31x12x4 FMIC
    Long Tube Headers
    2.5" mandrel bend True Duals With X Pipe and Dynomax VT Mufflers
    3.73s
    Built AOD
    Wide Ratio
    Art Carr Extreme OD lockout VB
    31 spline billet input shaft
    Lube Mod
    2800rpm Billet Dirty Dog Non Locking Converter
    Quarterhorse
    Innovate LC1 Wideband
    26x9.50x16 Mickey Thompson ET Drags
    Once i get it up and running again i will haul it up to madison and let the Wizard tune this thing! I hope to be deep into the 12s but you know how that goes....
    93 SC Red Auto 111k
    2013 Shootout Bracket ET First Place
    2015 Shootout Car Show Honerable Mention
    2016 Shootout Mod-1 First Place
    4.2, 2.3 Whipple, 3.73s AOD
    395rwhp 11.741@117.5mph
    90 SC 35th auto 84k
    NYC
    17,430
    Jacob how much power did your red car make with the morana B cam. I had a sim setup and it made like 316 or so at the rear wheels with an s port and stock valve ported heads
    Aug 2005
    Paoli Indiana
    4,563
    Quote Originally Posted by XxSlowpokexX View Post
    It peaked at 4000rpm and only made 213/265 which could mainly be because of the non locking aod setup i now run. Last year it made 205/305 but would only run a 9.9 1/8th mile and with the morana cam/ported heads setup it ran 8.90s which is nowhere on par with 213rwhp I hear the Morana cam is an NA cam. The only reason i ran it was it came in the motor i put in the car before the shootout. Said motor made 265 with a stock IC and a ported early model through a direct drive AOD and ran high 13s in the car it came out of. I swapped the ported heads on and had the s port FMIC etc running it through a non lockup setup. It had stupid bottom end torque but just wouldn't do anything past 4000rpm When i purchased the converter alan told me i'd never like the dyno #s but it would perform on the track. I'm assuming the setup on a direct drive aod or a five speed would have been right at 300rwhp. A good friend with a direct drive aod who runs the same gears (3.73s) runs right at 9.0's with 275rwhp and right at 100lbs lighter race wieght than my car so it makes sense.
    93 SC Red Auto 111k
    90 SC 35th auto 84k
    Aug 2005
    Paoli Indiana
    4,563
    Stage II of the new project complete!!
    First off i had to goto milford MI to pickup my new parts car. Dan had traded a guy in Cleveland a 32v cougar project for a 70k five speed. I left work at 3am friday and was running out of dan's place with the cougar by 5:30 and we made it to Cleveland and swapped cars way ahead of schedule!
    Next stop was Dan Sly's place in MI where i picked up this!
    We left sly's place just after dark and started having headlight switch problems on Dan's new ride (turned out to be crap radio wiring) so we called it a night
    South of florence we stopped to check straps and dan headed for his place and i headed home.
    I got home at 4:00pm and got the trailer dropped just before the snow hit!
    1099 miles towing! The old 208k truck did a good job never had a single problem and pulled the heavy birds without breaking a sweat. averaged 11mpg on the way up and 13.2mpg on the way back (kept the cruise on 68mph) FYI dan's new five speed car has 4.10s and mannaged 27.92mpg
    Overall a very successful trip! everything went smooth! the only hitch was me screwing up the winch cable at the end. It was great to meet the famous Dan Sly and Bill was cool as hell too! Now once the snow melts i need to make some room and get this car in the garage, pull the motor pull the heads swap cams MLS gaskets studs etc and start putting it all back together in my red car.
    93 SC Red Auto 111k
    90 SC 35th auto 84k
    Aug 2005
    Paoli Indiana
    4,563
    I started making progress on getting the motor out of my parts car.
    Welded heads with raised exhaust floor
    I need to blast and coat the long tubes
    Also replace the valve springs they are new but got rust from sitting.
    Heads are comming off to install ARP studs and MLS gaskets and i will check everything else out.
    93 SC Red Auto 111k
    90 SC 35th auto 84k
    Aug 2005
    Paoli Indiana
    4,563
    I finished pulling the motor/tranny out of the parts car today.
    93 SC Red Auto 111k
    90 SC 35th auto 84k
    Aug 2005
    Paoli Indiana
    4,563
    Well things took a major turn for the worse...
    93 SC Red Auto 111k
    90 SC 35th auto 84k
    Aug 2005
    Paoli Indiana
    4,563
    93 SC Red Auto 111k
    90 SC 35th auto 84k
    Sep 2004
    Herrin Illinois
    3,392
    Wow Bummer man.
    member #2488
    Aug 2005
    Paoli Indiana
    4,563
    Yep... really wish i wouldn't have sold my perfectly good low mile rebuild.... Ohh well... Stroker time!
    93 SC Red Auto 111k
    90 SC 35th auto 84k
    Sep 2004
    Herrin Illinois
    3,392
    Stroke it!
    member #2488
    Aug 2005
    Paoli Indiana
    4,563
    *Update*
    I purchased from SCU:
    New 4.2 crank
    Wiesco Forged Pistons
    Eagle H Beam Rods
    The block and parts are now all at the machine shop. So i should have a short block within the next few weeks!
    Also sent the heads of to clarks head guy and turns out the exhaust side majorly outflowed the intake! Also discovered that the valves are actualy 1.94/1.62 AND that the exhaust valves are stainless and the intake are NOT . Also the valve job on the intake side was crap! So they are getting ported properly a full valve job with new intake valves, and new springs to support my .605 cam.
    I also got a 135 amp alternator and am going to pickup a 10% MP crank pulley. Also got relayed wiring kit for the fuel pump to install.
    93 SC Red Auto 111k
    90 SC 35th auto 84k
    Sep 2004
    Herrin Illinois
    3,392
    Jacob the valves are 184 162 not 194 162
    member #2488
    Aug 2005
    Paoli Indiana
    4,563
    Quote Originally Posted by davec73 View Post
    ?? Pretty sure steve told me 1.94 on the phone but I have slept since then.
    93 SC Red Auto 111k
    90 SC 35th auto 84k
    Aug 2005
    Paoli Indiana
    4,563
    Looks like my short block will be done in a week or so.
    93 SC Red Auto 111k
    90 SC 35th auto 84k
  1. 93 Five Speed Restoration/Build Thread (Pic Heavy)
    By Jacob_Royer in forum Non Technical Forum
    Last Post: 07-29-2015, 11:00 AM
  2. Are non SC Build threads OK?
    By Silenced in forum Super Coupe Club of the Midwest
    Last Post: 11-25-2009, 08:15 PM
  3. 93 SC Rebuild thread...
    By Jacob_Royer in forum Technical Forum
    Last Post: 03-12-2007, 02:16 AM
  4. 95 SC's can stomp 93 SC's...* pic *
    By tbird88 in forum Non Technical Forum
    Last Post: 05-10-2002, 12:32 PM
  5. 93 SC for $4500 is it worth it?
    By geminiSC in forum Polls Forum
    Last Post: 03-05-2002, 03:02 PM
