Results 1 to 4 of 4
Thread: Asp UD pulley install?
    Dec 2008
    Randleman, NC
    299
    A few questions.
    1. What all do I have to remove from stock crank pulley to remove it? Just 4 bolts? Or does main crank bolt need to come out too.
    2. I have a small amount of end play in water pump shaft....but no issues with noise or cooling....should I replace or just wait for now....
    Any other thoughts while I'm in there?
    Jun 2008
    Columbia,SC
    615
    S this should be in technical right? The crank just needs the 4 bolts like you said, might be a bit rusted to the balancer.
    I went ahead and did the water pump when I did my bhj balancer as a precaution. Well I loosened the studs that connect to the block and apparently broke the timing cover gasket...so that was a lot of extra work for something that wasn't broken...I say leave it alone or risk having to pull the timing cover right after the install.
    Dec 2008
    Randleman, NC
    299
    Ok got them on.....gotta grab a shorter belt then I'll be all set!
    PNW
    6,401
    Quote Originally Posted by shocar4 View Post
    A few questions.
    Any sign of leak at the weep hole? Any idea how many miles on it?
  1. ASP Alternator UD Pulley
    By Duffy Floyd in forum Want to Buy
    Last Post: 06-16-2010, 01:19 AM
  2. 5% OD blower pulley and ASP ud pulleys
    By Burbank95sc in forum Parts for Sale
    Last Post: 03-29-2007, 11:25 PM
  3. ASP UD Pulleys
    By 89XR7TD in forum Parts for Sale
    Last Post: 09-23-2006, 08:03 PM
  4. 5% JS pulley and ASP UD pulleys
    Last Post: 06-30-2006, 07:19 PM
  5. WTB: Used ASP UD Pulley Set
    By SeanMatteson in forum Super Coupe Club of Ontario
    Last Post: 05-10-2004, 06:09 PM
