Results 1 to 13 of 13
Thread: New (to me) 95 SC Auto
    May 2006
    Chicago, IL
    920
    I just finished driving home in my new 95 SC Auto. It has 117K miles, rebuilt engine 45K ago, factory rebuilt Transmission 85K ago, new coat of paint in 06, a bunch of suspension parts over 2011 to 2013.
    I flew out to Philidelphia, bought the car and driove it home to Chicago, a grueling 14 hours on the road overnight, check engine light came on one hour into the trip and haunted me the whole way home. I was sure it was going to strand ... but it didn't! I'm really impressed that this car made the trip.
    I'm going to be driving it while I bring it up to a higher standard and want to make sure of a few things before I start shoping.
    First, the 94-95 SC's are all OBD1 correct?
    Sensors are pre-cat so I can run it catless, yes?
    I'm familiar with the early gen 1 SC's mostly the 5-speeds, what's different between the gen1's and gend2's besides cosmetic stuff?
    Thanks for your feedback, I'll keep you all posted on the progress of this project.
    Pretty clean, rust free undercarriage, however upon closer inspection yesterday the dreaded fender rot where the inner fender meets the side rail under the hood.
    3 SC's over a pair of SHO's ...
    Plat O Ribs Full House of SVT!
    SCCoA Member#: 3251
    Jun 2008
    Columbia,SC
    623
    "larger" MAF, larger injectors, square port sc with coated rotors, different gas tank that allows you to run true dual exhaust, different auto transmission, different ABS system that doesnt suck...larger pulley on the sc than an 89-93, and a windage tray in the oil pan?
    Apr 2011
    Brentwood, TN
    167
    A lot of other parts changed too in 94 so many parts in the engine begin with F4xx-xxxxx-xx
    Looks like the repaint of your car took it from Cameleon Purple to Black judging by the engine bay but you already know this?
    Nice survivor, enjoy it and keep away from further road salt if possible.
    1990 SC 5 Spd, Oxford White/Black Leather, 1 owner - "XB-70 - AV1" and Dragon Slayer on Epic Drive '18.
    1995 SC 5 Spd, OP White/Grey Leather, DLFs built car - "Mr. Hyde"
    1994 SC 5 Spd, Black/Grey Leather, all options, - "SR-71"
    1992 SC Auto, Oxford White/Black Leather, - "XB-70 - AV2"
    1990 SC Auto, 35th, all options, - "Phoenix Bird"
    1990 SC 5 Spd conversion, Red/Black Cloth, no options, - "Tampon IV"
    May 2006
    Chicago, IL
    920
    Quote Originally Posted by XB-70 View Post
    The color change was performed relatively Professionally, door jamb, trunk and underhood rails were all taped off and painted to make for a more finished look. the paint surface appears to have some wierdness but so far I have yet to wash it and inspect it carefully, oh and the color change was to a dark blue like my 89 blue SC.
    I'm trying to learn about the differences that will impact the things I want/need to fix first, I've got a small exhaust leak and was told by the seller it is a hole in one of the cat bricks so I'm planning on replacing the complete exhaust system with Mandrel Exhaust System (MES) parts. First question: What specifically are the differences between the Gen 1 & Gen 2 Manifold to downtube angles/orientationdown, downtube/cat.
    Josh at MES offered the following parts they are preparing to offer to ease retrofitting our exhausts with their parts. These are designed on the Gen 1 manifold/downtube angle/orientation, will they work on the Gen 2 or are the angles/orientation different enough that these parts won't work very well?
    PS: keeping this car out of the salt this winter is a no starter, it's my daily driver. However I'll clean it throughout this winter and come springtime I'll devise a plan to protect the undercarriage for subsequent bad weather. I bought this car because 1. My 89 5-speed was rotting out from underneath me, & 2. the slave cylinder I replaced a few years ago failed! So I very much understand the ravages Chicago winters subject our cars to. Fish gotta swim, man gotta work! I have a few project cars that will be stored during the winter, this won't be one of them!
    SCCoA Member#: 3251
    Dec 2008
    Randleman, NC
    299
    I just bought those dowtubes last week! On the way to me now! Yahhh
    May 2006
    Chicago, IL
    920
    Pretty sure they won't work on the Gen 2 application.
    SCCoA Member#: 3251
    Feb 2003
    Tinton Falls, NJ
    1,536
    The driver's side is the same, but the passenger's side comes out angled more on the newer manifolds where the older ones come out more pointing straight down. That pipe will not be a direct bolt-on swap, but it would probably be a decent starting point for an exhaust shop to cut and weld it to make it fit right.
    May 2006
    Chicago, IL
    920
    Thank for the confirmation Mike! Can I cut the OE down tube and use them as the starting place for the X-pipe retrofit from MES instead of using their gen 1 parts?
    I pulled codes last night after work.
    214 in memory, Cylinder ID (wiskey tango foxtrot?)
    623, A40D trnasmission referrence, (again ~~~?)
    My paper clip was old but I think I did it right, did it twice and got the same codes, so...
    TIA guys!
    SCCoA Member#: 3251
    Oct 2002
    Orland Park, IL
    223
    You bought another one
    Well let me know if you need any parts
    Aug 2005
    Paoli Indiana
    4,619
    Uhh oh.... Chris as your friend i have to say that since you bought another one its time for you to seak profesional help! Or we may have to stage an intervention before you get too far out of hand!! You obviously are trying to fill a void somehow by punishing yourself!
    Nice find BTW lol
    May 2006
    Chicago, IL
    920
    Quote Originally Posted by Jacob_Royer View Post
    Nice find BTW lol
    This is actually the second one I've bought in the last few months. I bought the white one Randy sold a couple of years ago that came back with blown HG's. after Randy put new HG's on it I went to pick it up and found there were other issues besides the HG's. Then the slave cylinder gave out on my Daily 89 5-speed.
    I really do need an intervention, or maybe just a bullit in the head!
    SCCoA Member#: 3251
    Mar 2010
    Grafton, OHIO
    647
    I would suggest changing the pass side manifold to late instead of cutting up the down pipe. They r supposed to be a step or two above the early manifolds as far as flow/balance. If you have the time, port them both as well. I think that even if you just R&R the pass side you would be performance ahead, and it would be a quicker/more cost effective fix than finding an exhaust shop and paying for what would amount to hack work on the pipe to make it fit.
    Just my $.02, if tis even worth that
    Adam
    Feb 2014
    840
    Looks like a nice one! 14 hours is a long drive (I only had to drive just over an hour out of town to get mine). How much did this SC set you back?
  1. New to me 1994 SC 5 speed...Teal v2.0 :)
    By CaifanSC in forum Non Technical Forum
    Last Post: 11-04-2017, 03:38 PM
  2. Electrical gremlins on new to me 92 SC
    By peagnit2 in forum Technical Forum
    Last Post: 07-09-2013, 01:36 PM
  3. New to me 92 sc
    By davec73 in forum Non Technical Forum
    Last Post: 10-18-2011, 08:02 PM
  4. new to me 92 sc
    By ghostryder in forum New SC Owner Forum
    Last Post: 07-21-2011, 03:14 PM
  5. Pics of my "new to me" SC
    By crich in forum Non Technical Forum
    Last Post: 10-23-2006, 08:51 PM
