Page 1 of 3 123 LastLast
Results 1 to 15 of 35
Thread: The saga of the Turd 2: Texas Turd Edition
    Sep 2011
    Mcallen TX
    778
    As some of you from FB may know
    my 92 tbird is getting just a few upgrades , bear with me when i say a few lol... its a long read you have been warned
    After owning this car for 3+ yrs in march its the 4th yr ive had it and lately this time it has evolved from the junk it once was i thank sccoa because if sccoa did not exist i had ditched this car a long time ago.
    No i dont care it had a wreck and no i dont care about 1000 other cars being cleaner or better its what i have ive learned about everything i know so far with it and to me thats much more valuable than a paper or a collectors edition this and that..
    I have removed about every bolt this car has and tried to improve it as much as i can
    So here is what is happening now
    Blower set up:
    I have ditched my manny SC coated mp3 blower with MP rotors and pulleys etc
    and got Miller's
    1.7L AR set up with an enlarged inlet and custom outlet and low intake manifold
    Top end:
    i also aquired Roadhawg's set of SCU heads
    quite a serious set of cylinder heads
    I dont know exact details just know its 1.94/1.70 valves
    yella terra adjustable valvetrain etc
    Motor:
    Ihave also had Xr7dave build me a forged shortblock and assemble the full motor for me
    just an SCU build , you know u can expect the top notch stuff from here
    it is remaining a 3.8
    JE coated pistons
    h beam rods
    windage tray
    new water pump
    hv oil pump
    SCU cam
    arp main studs and arp headstuds
    So far these will make a huge impact from what it ever was before.
    Now it doesnt stop there
    The transmission:
    the already home built AOD with almost all upgrades i could find if it doesnt last i will re do it until then it will stay it
    received a lentech Street terminator 2 vb
    a tailshaft lube mod
    a 4r70w tailshaft
    a deep LPW aluminum pan
    a tru cool 11x11x1.5 bar plate cooler
    10" fan for cooler
    a B&M hammer shifter retrofitted to it
    And a phantom 2 trans temp gauge
    Drivetrain wise:
    a 3.5" dynotech driveshaft
    a dirty dog driveshaft loop
    a 4r70w yoke
    Rear end:
    Freshly built 8.8 iron IRS
    3.73 ford racing gears
    pair of Early Fat halfshafts
    rebuilt T lok with 8 clutch set up
    solid pinion spacer
    lpw Cover/brace
    Fuel system:
    Dual fuel set up
    10gal polished fuel cell for race gas only
    -8AN feed lines
    -6AN return lines
    a1000 external pump for the race gas
    On the stock tank
    a 340lph aeromotive stealth pump
    with a racetronix wiring upgrade kit
    also -8an feed -6an return lines
    80LB siemens deka injectors
    Custom AR fuel rails
    bbk adjustable FPR
    Cooling system:
    this is staying pretty much the same as before
    29x19x3 full aluminum radiator
    adding a mark 8 fan to it
    Air charge cooling:
    is still my same huge 36x14x4 Fmic set up with 2.75" piping i will however get some pipes welded
    adding 2 puller fans to the IC and 1 pusher fan on the condenser
    Air intake:
    i have ditched the 85mm C&L
    and gone slot maf on my previews 4" intake pipe
    however i will be using a 95mm MP TB that meets the enlarged 95mm AR inlet
    Exhaust :
    redoing complete exhaust system
    dual stainless mandrel bend 2.5 kit
    magnaflow resonator
    keeping borla mufflers
    3.5" gibson tips
    Kooks midlenght headers with vibrant v bandz
    no cats
    Pulleys:
    i have quite a variety now
    the idlers will be 76mm billet alum from thump racing
    have a nice alum PS pulley
    the SCI underdrive pulley set up
    have 2 alum pulleys for the AR
    and have 2 alum SCI JS pulleys 5% and 10%
    for different boost combos
    Suspension:
    i have all 4 1.6" drop vogtland springs
    4 tokico illumina 2s
    2 rear lakewood 50/50 drag shocks
    airlift air bag kit for the rear
    new front raybestos pro suspension kit
    rear Alum mark 8 LCAs
    derlin LCA and knuckle bushings same as DLF just now made by jay richmond
    cobra spring isolators
    and the DLF spring perches
    Brakes:
    front cobra calipers with ceramic pads
    Drilled slotted rotors all around
    rear are staying stock size with stock caliper just new drilled slotted rotors with ceramic pads
    stainless steel brake lines all around
    Tuning:
    Quarter horse
    mtx l wideband
    BE
    tuning getting done by Dave D
    Body:
    lift off 3" light weight hood
    this alone removed about 60lbs
    latch and stock hood were 70ish lbs
    new hood is only 13lbs a few trims and small things
    ill list once i do em
    Rims and tires
    keeping the cobra Rs
    i ditched the 315 35 17 nittos and got a pair of 295 45 17 MT drag radials for street driving
    i also got a pair of 16x8 cobra Rs that will receive 28x10 hoosier slicks
    front tires will be 245/55 or so these i havent bought but need to be same or close as MTs 27.2" tall
    i will also get some skinnies for the front sometime soon
    Retained tbird pattern all around
    Other power adders:
    zex wet nitrous kit
    have every safety feature possible just in case
    purge kit
    automatic valve opener
    window switch
    bottle heater
    Pressure gauge
    bottle blanket
    etc etc
    Also have a methanol injection kit snow stage 2 that i will more than likely use as well
    Interior:
    building a custom speedo
    gutted undercarpeting
    redoing the interior colors and possibly ditching the stock seats
    also have an 8pt roll bar/ cage that will come in some time soon
    Thats as much as i can top off my head i will began to post pictures and updates of my progress as it goes along
    Sadly this was way too much to finish in a small time frame so it will take longer but it will get finished
    Btw thanks to all the ppl who have sold me parts and given me a break with prices over the yrs its cost me alot so far and its not even done it would have been double had i not bought most my parts from you guys
    thank you for all the tips and teachings as well
    and specially Dave Dalke thats helped me out throughout the time ive owned it
    Now you all can start guessing what it will make or what it will run... i have my own expectations for it lol  and hope to be done for shootout this year
    Jul 2013
    LI, NY
    788
    I have always enjoyed your posts on FB and on here. Good luck with the build. Looks like you put a great deal of thought into your upgrades. I am sure it will be one fast lead sled...
    21,099
    Miguel,
    Looks like you have everything covered for running mid 11s off the bottle, and mid 10s with the nitrous. Looking forward to seeing more pictures.
    Sep 2011
    Mcallen TX
    778
    Miguel,
    Thats the plan david we shall see how it goes as soon as its put together
    Sep 2011
    Mcallen TX
    778
    Quote Originally Posted by jjklongisland View Post
    Thanks, i hope so i gather some pics im uploading now
    Having some re sizing issues with all the files will have to re size them all to be able to upload them
    Feb 2014
    840
    Sounds like a great build! I can only imagine the money that you'd spent. It's interesting that you said that you don't care that your car was in a wreck.....mine is a rebuilt status, from various donor cars. The guy that I bought it off of had done it, and had done a pretty good job.
    Apr 2013
    Brighton, MI
    455
    Good job Miguel cant wait for you to get it done. Maybe you will be satisfied now!!!????
    Sep 2011
    Mcallen TX
    778
    Quote Originally Posted by 1FSTBRD View Post
    Thanks buddy yes sadly it was in a very minor wreck the damage was little to none really but insurances rather declare it salvage as a total loss and pay less than what its worth fixing in their books
    Sep 2011
    Mcallen TX
    778
    Quote Originally Posted by elanoresc View Post
    Mike i know i wont be doing alot to it any soon just wanna finish and enjoy it for a long while actually my truck needs some attention so im doing a few things to it and thats what i will focus after the birdy is running
    maybe a turbo on the 5.4 and some body upgrades
    Sep 2011
    Mcallen TX
    778
    Here is a couple pics right before i started to take it apart, while moving it to the new house we had the front bumper get caught up with the trailer and it tore up but luckily ive got a spare to put on the hood is not aligned it's just mocked on top
    Apr 2013
    Brighton, MI
    455
    Looking good Bro i am going to keep eyes on the build
    Apr 2013
    Texas
    101
    Hood!
    Where did you find that hood- I like its design better than whats available for our birds. Let me know where you got it, brand name anything!
    Nov 2010
    Bay Area
    543
    I think he got it off Jegs if I remember correctly http://www.jegs.com/i/US-Body/277/TB...ductId=2867844
    Sep 2011
    Mcallen TX
    778
    Quote Originally Posted by WES92SC View Post
    Yes its off us body called gt 41 3" cowl hood
    order directly tho its better and its a lift off hood weights about 12lbs requires 4 pins tho no latch used
    Sep 2011
    Mcallen TX
    778
    Ive been reducing some.of the pictures resolutions but its many and my computer took a dump on me
    but here is a few i was able to do on the phone
  1. Ran out of gas and car not the same N.E. more
    By scbird94 in forum Technical Forum
    Last Post: 10-13-2004, 04:21 PM
  2. gas and spark but no fire?
    By 5speedxr7 in forum Technical Forum
    Last Post: 09-04-2004, 11:01 PM
  3. New e.t's good and bad
    By Jake in forum Super Coupe Club of Florida
    Last Post: 03-28-2004, 12:06 PM
  4. New Macs slaughter Pentium 4 and Xeon lol
    By 1BADSC in forum Non Technical Forum
    Last Post: 07-01-2003, 12:39 AM
  5. New multifunction switch&wiper motor and no wipe
    By WBK89 in forum Technical Forum
    Last Post: 06-25-2003, 06:30 PM
