Results 1 to 7 of 7
Thread: AN Power steering conversion
    Sep 2006
    NE, AR
    1,570
    To those of you that have done the conversion posted on TCCOA and what all needs/should be removed to get the job done? Also how much line was used ( I have 6' so it not an issue just curious)?
    Feb 2003
    Tinton Falls, NJ
    1,505
    I used about 3ft of line. Only thing I had to remove for access was the washer reservoir to have better access to the fitting at the back of the pump.
    Imperial, MO (near St. Louis)
    4,332
    I find it easiest to mock up with the engine in the car, then pull the engine to install at the rack.
    Sep 2006
    NE, AR
    1,570
    Well after doing the shocks on my wife's Marquis, took a look at this and all I can see is the IC needs to come out.
    Mar 2010
    Grafton, OHIO
    623
    Doing this on my '90 Cougar, just want to confirm, directions r a little vague.... Does the 16-1.5 on the rack end go to orig 90, or directly into
    rack? Both have same fitting/o-ring, and if I'm reading right the adaptor/45 goes into the original 90 fitting. Just trying to double check b4 fighting rack back....
    Thanks
    Adam
    4,332
    The adapter installs into the original rack fitting.
    Mar 2010
    Grafton, OHIO
    623
    Cool. Thats what I thought, just wanted verification b4 fighting the rack back in.
    Thanks
  1. help,need power steering pulley
    By eds94tbirdsc in forum Super Coupe Club of Ontario
    Last Post: 07-28-2015, 08:34 PM
  2. power steering
    By ryan a harris in forum Super Coupe Club of Ontario
    Last Post: 05-25-2002, 08:20 PM
  3. power steering problem?
    Last Post: 05-18-2002, 10:28 AM
  4. help, power steering pulley
    By eds94tbirdsc in forum Non Technical Forum
    Last Post: 05-14-2002, 12:10 AM
  5. power steering pulley broken
    Last Post: 05-10-2002, 12:54 AM
