Results 1 to 12 of 12
Thread: new (kinda) from socal
    Apr 2015
    8
    planning up picking up a 93 aod sc for next to nothing but of course the catch is a blown head gasket. planning on making this a bit of a toy car and not a daily driver. i've owned a 97 sport, sold it a while ago. plan on picking it up tomorrow will post some pics.
    Apr 2015
    8
    more pics as i can only attach 5
    Apr 2015
    8
    so as you can see the spark plusg are dead, car cranks and wants to start but does't. no weird noises coming from the engine while it cranks. the sparks plugs that were pulled were the two rear most on the drivers side.
    looks like it has a pretty decent oil leak i need to track down.
    also there is a plug pictured coming off the maf, i have no idea what this is supposed to go to but i assume it's rather important if it comes off the same pigtail as the maf wires. shown on this reply in the pictures
    there's another plug that is shown hanging near the master cylinder, comes off a bundle of wires about 1" in diameter, i looked to see if anything looked like it wasn't hooked up and couldn't find anything. also shown in this reply's picture.
    PNW
    6,586
    That loose connector by the MAF appears to be for a coolant level sensor in the overflow tank - I notice your tank doesn't have the hole for a sensor. In the dash, above the radio, is there a small display or just a blank off panel? If you don't have the display (VMM), then that connector isn't used.
    The other one looks like maybe it goes the washer fluid level sensor...if you have one. That would be another part of the VMM display.
    It might be interesting to check for any codes to see what the car has to say about it's current condition.
    Apr 2015
    8
    ah ok that makes sense yeah it doesn't have the vmm.
    i dont even have an obd1 reader lol. i've only had ob2's and an sct 2. i guess i will have to grab me one hopefully autozone carriers them still.
    PNW
    6,586
    AZ, eBay - should be less than $40. AZ might even read them for you for free.
    Apr 2015
    8
    ha i'm surprised they still sell em. guess that will be the first purchase although this motor is looking toast. plugs are deader than last years romance, no coolant in the radiator. i'm almost afraid to drain the oil in this thing. i have a strong feeling i will find chocolate milk for oil.
    guys said the water pump blew, but i think the head gasket blew. or if the water pump did die it cooked the motor and killed the gaskets. need to spend a week and open the motor and see what's all up with this thing.
    only reason i bought this was it was 400$
    PNW
    6,586
    Stick with it and good luck.
    Apr 2015
    8
    i plan on it, been around these cars since i was a kid, uncle had several. matter of fact was a member here years and years ago had a 1st gen sc show car same color as mine (midnight blue?) anywho luckily i can bounce issues off him. but for the most part pretty familiar with these cars.
    i think i will be needing much more luck than i can see oh and $$$$$
    May 2012
    Denver Area
    803
    You don't need a code reader - you can run all the tests with a jumper wire and your check engine light.
    http://sbftech.com/index.php?topic=2471.0
    Apr 2015
    8
    thanks for the diy! might as well save some bucks where i can.
    Sep 2014
    Broken Arrow, Ok
    196
    Why do your pics look like they were taken from a camera from the 1970s? lol
  1. New Times from the weekend
    By Melon in forum Racing/Track Results
    Last Post: 10-20-2004, 12:51 PM
  2. New pic from Sarah
    By Jason Parham in forum Super Coupe Club of the Southeast
    Last Post: 10-09-2003, 02:22 PM
  3. new guy from Ohio reading up
    By Kwik in forum New SC Owner Forum
    Last Post: 10-30-2002, 08:24 PM
  4. new to the SoCAL board. LACR??!!
    By SCroots in forum Super Coupe Club of Southern California
    Last Post: 10-30-2002, 06:51 AM
  5. New beatings from the 'hood
    By rotorhead100 in forum Non Technical Forum
    Last Post: 08-05-2002, 06:39 PM
