Thread: Upgraded fan wiring
    Apr 2015
    12
    Upgraded fan wiring
    Guys my school has a upgraded fan. It runs all the time. There is a brown yellow wire a brown wore and black
    Is there a way to have the fan come on when the controller tells it to or am I running new wiring ? This controller did work back in the day I swapped out the stock fan however the car won't warm up at all so I'd like it to come on when it should not all the time.
    Suggestions
    Salem OR
    7,488
    If it used to work and now it doesn't, you might need a fresh/new controller. What brand is it?
    Apr 2015
    12
    Fan
    It's a after market fan 2 wire. I know the stock was two speed I'm assuming the brown and brown yellow trigger slow or fast speed ? I think in going to get a separate controller that mounts in rad
    QUOTE=KMT;1085743]If it used to work and now it doesn't, you might need a fresh/new controller. What brand is it?[/QUOTE]
  1. cooling fan wire 14?
    By stephens89sc in forum Technical Forum
    Last Post: 12-23-2002, 07:47 AM
  2. #14 fan wire...where to find?
    Last Post: 07-24-2002, 09:44 PM
  3. LES - ? about #14 Fan Wire
    By JT93SC in forum Super Coupe Club of Ontario
    Last Post: 07-11-2002, 07:32 AM
  4. Fan wire
    By ryan a harris in forum Super Coupe Club of Ontario
    Last Post: 06-08-2002, 12:18 AM
  5. PIN 14, low speed fan wire?
    By Tubeamp in forum Super Coupe Club of Ontario
    Last Post: 04-26-2002, 09:06 AM
