Results 1 to 5 of 5
Thread: Question about aftermarket oil press sending unit install
    Howell, NJ
    1,708
    I want to install my new oil pressure gauge. I'd also like to keep the stock gauge hooked up and working as well.
    If I use the tee fitting pictured below, do I also use the stock stalk/ fitting in the other pic?
    I don't see how i would be able to squeeze the two sending units into that tight space unless I use both the stock stalk along with the tee.
    Sep 2006
    NE, AR
    1,570
    I'm using the OEM stalk and a Tee
    Howell, NJ
    1,708
    Quote Originally Posted by bowez View Post
    Great thanks!
    St. Louis, MO
    6,541
    I used a brass close nipple, a brass tee and a brass street 90. Mine is offset a bit because I'm using a mechanical gauge and have braided SS hose attached instead of a sending unit.
    Here's a picture from my garage page.
    http://www.sccoa.com/forums/garage_a...ent.php?id=687
    Kurt K (e-mail)
    SCCoA Member #: 443
    Howell, NJ
    1,708
    Quote Originally Posted by Kurt K View Post
    Thanks Kurt! I actually stumbled on that pic last night while searching. I'd like to fit both the oem sending unit and the new gigantic sending unit that came with the gauge in there. I like the idea of being able to get the warning light on the dash if I should have a serious oil pressure problem...
  1. Oil pressure sending unit
    By the-big-e in forum Technical Forum
    Last Post: 12-22-2004, 05:24 PM
  2. Oil pressure sending unit
    By 77fordman in forum Technical Forum
    Last Post: 07-13-2003, 10:02 AM
  3. oil pres.sending unit
    By pete buck in forum Technical Forum
    Last Post: 06-09-2003, 12:23 AM
  4. Question about aftermarket stereos
    By SpaceGhost in forum Non Technical Forum
    Last Post: 05-13-2003, 10:28 PM
  5. Question about putting in a head unit
    By TbSCbos13 in forum Technical Forum
    Last Post: 01-23-2003, 05:47 AM
