Results 1 to 15 of 15
Thread: WTB 85mm throttle body
    Apr 2015
    Crossville, IL
    62
    I'm looking for an 85mm throttle body that will fit the Magnum Powers intake plenum.
    Last edited by tberger06; 07-05-2018 at 08:22 PM. Reason: updated what I'm looking for
    Oct 2005
    2,288
    I have the battery hold-down, the spare tire handle, the power antenna switch and a mirror switch.
    The antenna switch and mirror switch have been tested in one of my cars and are good.
    I might know where a set of cowl pieces are but I have to check first.
    Jim, SCCoA Member#: 2789
    "cuz Jim has mad skillz, yo!" Melon.
    "You guys crack me up talking about nitrous when you don't even know if you can keep it together on gasoline." XR7 Dave
    "I didn't break it, I found it's weakness."
    Dec 2010
    Zephyrhills F.L.
    183
    Most any junk yard for the cowl pieces and the trunk lock complete with a key it's easy to remove and they're all the same, Permatex plastic welder for the doors and misc other parts. Most parts stores carry it and it really does work.
    Apr 2015
    Crossville, IL
    62
    Quote Originally Posted by TSC89 View Post
    Do you know of a way to determine if my mirror controls are actually broken (or if it's the mirrors themselves)?
    Also, I don't need the antenna switch...just the outer bracket that secures it to the dash.
    Let me know if you are successful or not with the cowl pieces, then we can arrange something.
    Quote Originally Posted by fstcoup View Post
    I was attempting to change my trunk lock but could not remove the black & white plastic pieces without breaking them. Is there a trick to getting them apart?
    Oct 2005
    2,288
    Quote Originally Posted by tberger06 View Post
    On your mirror switch, roll your drivers side window down and then start pushing the mirror switch.
    See if you can hear the motors running in the mirror.
    If you hear the motors run but the mirror doesn't move, it is the gears in the mirror.
    Make sure you test all the positions.
    You can test the passenger side the same way.
    If you don't hear them running it is probably the switch.
    There is a possibility that it could be both.
    As for the antenna switch, I tried to separate a bracket from a switch and it snapped. Not going to ruin another one so hopefully someone else has a bracket for you.
    Apr 2015
    Crossville, IL
    62
    I checked my mirror controls and couldn't hear anything moving in either mirror, so I'll give new switches a try if you have them.
    My original post has been edited because I no longer need the spare tire handle or trunk lock pieces.
    I found some cowl pieces off a 94 Thunderbird LX and although they are the correct size and shape, the screw holes do not match up .
    Oct 2005
    2,288
    Sent you a PM with details.
    One other thing on the mirrors, did you check the fuse?
    Apr 2015
    Crossville, IL
    62
    Doh!...the fuse has been the problem the whole time. I never realized there was another fuse box under the steering wheel. Popped in a good fuse and now my mirrors work along with all my interior lights and my door keypad!
    Only one small issue with my mirror control. One of the little internal plastic arms refuses to go up & down. It's the one that isn't all the way up in the picture. I am baffled why it won't move since the other ones easily slide up & down in their groove.
    Apr 2015
    Crossville, IL
    62
    Original post edited again to remove some items...and bump.
    Apr 2015
    Crossville, IL
    62
    Updated post that I'm looking for underdrive pulleys.
    Madison, Ohio
    17,586
    I have a set. $140 shipped.
    Email me here.
    Apr 2015
    Crossville, IL
    62
    Do these pulleys allow for the stock belt length? If I pair the crank pulley with the Dayco/Powerbond balancer, do I need to worry about getting them balanced?
    Madison, Ohio
    17,586
    I wouldn't worry about balancing, all the parts involved are neutral balance. This particular pulley set was installed on one of the early Dayco balancers that didn't have the correct offset on the bolt holes so I machined this crank pulley to match and so now it can be used on both with no issue. You can use the stock belt with this, although it does come super close to touching. I've run this pulley set many years with no belt issues, but you can run a shorter belt to keep it further from touching if you prefer.
    Email me here.
    Apr 2015
    Crossville, IL
    62
    PM sent for pulleys.
    Apr 2015
    Crossville, IL
    62
    bump for updated WTB
  1. WTB: 89-93 5-speed SC or Cougar XR7.......
    By phils89sc in forum Want to Buy
    Last Post: 11-26-2010, 01:26 PM
  2. Wtb: 89 xr7 mafs
    By rad_al_ in forum Want to Buy
    Last Post: 07-10-2009, 09:55 AM
  3. WTB 89-90 XR7 5-Speed Car
    By kylecoz88 in forum Want to Buy
    Last Post: 04-17-2009, 12:44 PM
  4. WTB 89-95 SC or 89/90 XR7
    By SC1day in forum Want to Buy
    Last Post: 01-31-2009, 10:58 AM
  5. WTB 89-95 SC or 89-90 XR7 Parts car
    By Storm_Dragon in forum Want to Buy
    Last Post: 09-25-2008, 09:57 PM
