pbdevastator
Few weeks back i posted about car wont try to start, it is a 1990 so it does require brake pedal to be pressed to start. Finally had some time to get back at it. So if I use the by pass trick that by passes the ignition switch and brake pedal it does start no issues. We tested to see if we get power to the wire that comes from ignition switch when trying to start car, we did not. Since we have steering column all torn apart and put a new ignition switch in. Was hoping and actually thought for sure that was it, but car does same thing it will not do anything when trying to start it. It does the same thing as if I didn't have brake pedal pressed down. So no clicking or anything just dead. My dad wanted me to ask if there is a fusable link somewhere and what else could be the issue? Brake lights do come on when pedal is pressed btw. Also again today we were able to bypass everything and car started fine. Hopefully I have enough detail here for someone that knows more about cars can quickly give some guidance. Appreciate any help on the matter.
