figulaz
looking for practical advice for getting my AC going. I've had the system open for some time (over a yr) and don't want to break the bank replacing everything and I'm seeing a couple options.. plan is to change seals, vac out and one of the following.
a. I see R-12 on ebay.
b. regarding r-134 ...." After a couple of years most service shops found that just adding ester oil, replacing the accumulator, and leaving any remaining mineral oil in place provided acceptable performance, in practice".
c. I've also seen R-134 with anti-moisture/corrosive mixed in.
d. also on Ebay...12A
HC-12a, also called ES-12a, OZ-12a, and Hydrocarbon Blend B, is a "drop-in" replacement refrigerant for Freon-12 and to a lesser extent, R-134a. HC-12a is a mixture of hydrocarbons, specifically propane (R-290) and isobutane (R-600a), and is therefore considered nearly non-ozone-depleting when compared to dichlorodifluoromethane (R-12, Freon-12) or 1,1,1,2-tetrafluoroethane (R-134a). The mixture can be used in refrigeration systems designed for R-12. HC-12a provides better cooling than an R-12 system retrofitted to R-134a, with much greater energy efficiency as well. Unlike R-134a, HC-12a is completely compatible with the hoses and oils used in R-12 systems, making the conversion much easier to accomplish. HC-12a is also patent-free due to its non-synthetic nature.
Disadvantages to using the HC-12a mixture in R-12 systems is that it is potentially dangerous and is illegal in the United States. The refrigerant used is propane and other hydrocarbons which are flammable. However, it should also be noted that R-134a (and other refrigerants) are just as flammable when mixed with refrigerant oil, yet the quantity of refrigerant and oil in a typical system is so low that the danger in any case is minimal.
e. stop being a wimp and just deal with no AC.
