Results 1 to 8 of 8
Thread: Just got a 1989 barn find 54K car need parts
    Oct 2015
    In a house
    4
    I just rescued a 1989 SC 5 spd car with only 54k miles on it. The original owner showed me the engine was replaced by ford at 25K miles as part of a recall. It was literally in a barn with snakes under the hood. Original owner had owned the car since new.
    I am looking to get suspension parts for it. The bushings have all rotted out from sitting. and the auto adjust shocks are bad. Is there a way to get rid of the auto adjusting shocks completely and use normal variable rate springs and shocks? Possibly a lowering kit to make it corner like it is on rails?
    any help on what to get would be great.
    Jan 2003
    Woodbridge, VA
    5,068
    Yes I believe all the bushings are still available. And yes you can get regular shocks. Super coupe performance has lowering springs.
    ~Chris
    SCCoA Member #1826
    Bettie Riding jack stands
    SCARlet on drag duty now
    Franklin,Mass
    380
    Strut rod bushings from Ford are all obsolete, check eBay.
    Joe
    May 2012
    Oregon
    756
    http://www.aftermarketsuspensionpart...underbird_1989
    Better than eBay IMO. I re-built my 94 suspension - good stuff!
    Oct 2015
    In a house
    4
    more info on standard shocks
    If I install non ride control shocks do I have any other issues with the ride control system I will have to deal with? looks like a pretty complex system, that it ties into the abs and other things as well?
    Salem, OR
    6,283
    Well, unless you remove the bulb from that slot in the cluster, you'd have to stare at the light flashing all the time. Then there would be the actuators still actuating, but you could unplug and discard them too.
    Otherwise, I believe the rest of the system would just assume the ARC shocks are still involved, but offline, and go about it's business as usual.
    As for being on rails, fatter sway bars would be a big step in that direction. If you lower it, be sure to re-establish the proper end link geometry, at least on the rear. If you've owned/worked on IRS cars in the past, all this shouldn't be too hard to get right.
    About bushings, etc., this is a must read thread, I think:
    http://www.sccoa.com/forums/showthre...light=bushings
    Oct 2015
    In a house
    4
    More info need please.
    Please ignore my ignorance with the super coupe. I have owned mostly mustangs till I found this barn find. Please don't hold it against me.
    But it states different bushings for a MN12ís and FN10ís. How do I know which one I have? A MN12 or FN10. Mine is an all original 89 super coupe with a 5 spd.
    Salem, OR
    6,283
    Thunderbird/Cougar vs. Lincoln
    See https://en.wikipedia.org/wiki/Ford_MN12_platform
    You have an MN12.
  1. Replies: 6
    Last Post: 06-23-2014, 02:17 AM
  2. just got back from a car show :)
    By pdennis93 in forum Non Technical Forum
    Last Post: 08-18-2003, 02:05 AM
  3. i just got back
    By mercury65 in forum Super Coupe Club of Southern California
    Last Post: 05-19-2002, 06:07 PM
  4. just got back from lake isabella saw a 95-56 thundermerc
    By mannysc in forum Super Coupe Club of Southern California
    Last Post: 05-14-2002, 07:19 PM
  5. Just got an 89 xr7 w/5-speed last night
    By 89xr7man in forum New SC Owner Forum
    Last Post: 05-06-2002, 02:59 PM
