Results 1 to 8 of 8
Thread: 1989-1991 Cat-back exhaust (and tank if needed) - Local Pick Up
    Dec 2002
    Merrimac, MA
    252
    Seeing if there is any interest in this. The pipes and mufflers have 16k miles on them and are in good condition. No leaks, no wholes, no rust. The resonator was replaced with a magnoflow dual in single out (about 400 miles ago). The resonator is welded directly to the tail pipe and should clamp up to your down tubes in the stock location (dual 2" in, 2.5" out). I used band clamps so the pipe isn't crushed. This would be local pick up. Basically just looking to recoup the cost of the resonator. $100 for everything. If there is interest in the matching fuel tank (which has a perfectly functioning OEM fuel pump), I'll throw that in for another $50. Location is 01860. Also would be interested in trades (late model fuel tank maybe).
Size:  405.7 KBName:  IMG_1674.jpg
    1989 XR7 5-SPD - 15,700 miles - Garage Queen
    Jan 2016
    ohio
    23
    any chance this could be shipped at all
    Dec 2002
    Merrimac, MA
    252
    Quote Originally Posted by Elsyiana View Post
    I suppose anything is possible. Update: I'm keeping the tank. I have the exhaust off the car now, all in one piece, hangers intact. The only difference between this and the stock system is where the flange used to be behind the resonator is now welded and there are no hangers on the resonator, those are now on my down tubes which don't come with the system.
    I think it would be prohibitively expensive to ship it as one piece but a few strategic cuts might get it into some kind of freight packaging and save some bucks. Any members here have suggestions for shipping this? I really don't want to make money off this, I just don't want to scrap what is a perfect resonator, pipe and low mileage mufflers.
    Feb 2003
    Phildelphia, PA 19030
    2,181
    Cool i would want only the rear exhast from the flange behine resanator
    u could make 3 cuts 2 on the straights after the split going 2 each side between the turns before going into the front of the mufflers about center from each turn the last is on straight betwneen hanger at punkin and flange give u 110 shipped as u can still sell front end i,m in pa 19030 cheapest way
    Feb 2003
    2,181
    Cool I even can make it shorter
    The last cut could b right near hanger between punkin and gas tank on the straight section in middle cut right after tun at gas heat shield and before next going 2 hanger let me know asap thanks :d
    Dec 2002
    Merrimac, MA
    252
    bump
    exhaust system only, local pickup.
    Dec 2002
    Merrimac, MA
    252
    Bump. I don't want to junk this.
    Dec 2002
    Merrimac, MA
    252
    Still hanging from the ceiling in my yard shed...
  1. 1991 Original SC Cat back Exhaust system for sale
    By jchinik in forum Parts for Sale
    Last Post: 08-21-2012, 08:41 PM
  2. Flow Master cat back exhaust system
    By the-big-e in forum Parts for Sale
    Last Post: 03-17-2005, 03:40 PM
  3. Cat back exhaust system
    Last Post: 03-27-2003, 08:34 PM
  4. SCP High Flow Cat-Back Exhaust System
    By wwotr in forum Non Technical Forum
    Last Post: 01-24-2003, 11:09 PM
  5. SCP High Flow Cat-Back Exhaust System
    By wwotr in forum Technical Forum
    Last Post: 01-24-2003, 08:44 PM
