ghostryder
need some help I am removing the timing cover due to a leak in the lower right corner by the crank position sensor. I removed the water pump and the 8 bolts that hold the timing cover on. also removed the camshaft, and the oil cooler, but the cover still wont come off. and I did remember the allan bolt in the lower left corner of the timing cover.
need some suggestions on getting the timing cover off
thanks
thanks
