Results 1 to 7 of 7
Thread: Ground cable connections
    Sep 2002
    Reisterstown ,MD
    171
    Can anyone tell me what all connections are on the ground cable, 1989 S/C?
    Salem OR
    7,438
    Quote Originally Posted by plstktnkr2 View Post
    All grounds, or just the larger ground cables inside the engine bay?
    Sep 2006
    NE, AR
    1,570
    Wise Guy answer: 1 The frame
    Sep 2002
    Reisterstown ,MD
    171
    I found my answer. connections are battery on one end on the other engine, core support, and 1 unidentified plug in, good enough for what I needed
    Salem OR
    7,438
    Be sure that includes the short cable from the pass. side motor mount bracket over to the body.
    Individual ganged harness grounds are identified via the EVTM for your year SC.
    Sep 2002
    Reisterstown ,MD
    171
    thanks for the help guys
    Jan 2010
    Bossier City, LA
    2,301
    That plug in isn't unidentified; it's the ground for the ECU, and is rather required to keep your Ford from becoming a bit schizoid.
    As in "Am I a V6, a V8? I know! Let's do SEVEN cylinders per revolution!!! Bwahahahaha!!!!!!" kind of schizoid.
    RwP
  1. ground cable
    By jasond in forum Technical Forum
    Last Post: 09-15-2012, 07:28 PM
  2. Replies: 3
    Last Post: 05-12-2012, 11:28 AM
  3. The Search for the Negative Battery Cable Ground
    By C5 Corvette in forum Technical Forum
    Last Post: 01-28-2005, 11:24 AM
  4. Cable In Front Of Abs System Needs To Be Grounded?
    Last Post: 12-17-2004, 11:02 PM
  5. Replies: 7
    Last Post: 09-04-2002, 12:08 PM
