Results 1 to 7 of 7
Thread: First track outing of the year
    Aug 2005
    Paoli Indiana
    4,614
    I hit Ohio Valley Raceway for the street car shootout friday. Weather was super humid and super hot and track prep was craptastic! This was my best pass and the only sub 2.0 60' of the night (normaly i run 1.70/1.72 I actually ran my nitrous tune (without spraying) because of the reduced timing just to get it out of the hole without spinning as badly. I was hoping to break into the 7's but it wasn't going to happen with the weather and track prep. The car ran consistant 12.70s /107.7/108mph with 8.1/8.15 1/8th miles last year @ the shootout with less boost. The street car shootout program consists of a 6.60/7.60/8.60/9.60 index heads up classes. I ran the 8.60 class and broke out first round badly with a 8.45 to a mustang with a 8.55 (he was also sand bagging lol) Had a good time anyway and learned a couple things! One being that the air bags in the rear springs make my 60' times ALOT worse so i dropped pressure down to 5psi! Also i normally run 14/16psi in my slicks and took them down to 12psi and did NOT like how the heavy azz car feels at all! Here is a video of one of my passes the wife cought 8.41 if i am not mistaken.
    https://www.youtube.com/watch?v=JG6HEI49Hp4
    Jun 2005
    181
    Dang that MPX makes some serious noise... good stuff
    '93 SC 5-speed, PTE 6062 powered
    Aug 2005
    Paoli Indiana
    4,614
    Quote Originally Posted by plethaus View Post
    Yes it does!!! As much as I want a tvs I will always love the sound of this blower
    Mar 2013
    Ohio
    21
    I'm just wondering if you attended any "drag week" events last year. I feel like I saw this car in the parking lot?
    May 2015
    68
    That thing is loud! What is the exhaust, cam, and boost psi (if you don't mind sharing)?
    Aug 2005
    Paoli Indiana
    4,614
    Quote Originally Posted by Twohaggard View Post
    Nope i sure didn't although i'd like to one of these days.
    Aug 2005
    Paoli Indiana
    4,614
    Quote Originally Posted by 20psiofevil View Post
    Here is the rundown.
    4.2 crank
    scat h beam rods
    wiesco forged pistons
    ARP Main studs
    Big valve ported heads with comp tripple beehive springs
    ARP head studs
    MLS Gaskets
    1.73 roller rockers
    .605/.604 226 duration cam
    340lph aermotive stealth fuel pump
    #80 Injectors
    85mm MP TB
    3.5" intake with slot maf
    MPX w/gtp rotor pack
    31x12x4 FMIC with 2.75" tubing
    MP 10% crank pulley
    MP 13% 10 rib JS
    MP 10% 10 rib blower pulley
    Kooks Mid length headers
    2.5" catless downtubes
    X pipe
    Magnaflow bullet resonators
    2.5" true dual mandrel bent exhaust
    OEM 05/10 mustang GT mufflers
    3.73 gears
    Rear air bags
    1.5" drop (cut springs)
    Buillt AOD
    31 Spline Billet input shaft
    9" dirtry dog billet 2800rpm non locking converter
    ART carr extreme OD lockout Valve body
    wide ratio 4r70w gear set
    mechanical diode
    2" od band
    alto red clutches
    a+ servo
    Zex Dry Nitrous Kit (yet to get a full pass on)
    I see about 16psi tops on boost
  1. First pass of the year.....
    By Ken Seegers in forum Racing/Track Results
    Last Post: 03-21-2011, 07:03 PM
  2. Motor Trend Car of the Year article
    By haskett in forum Non Technical Forum
    Last Post: 07-28-2009, 06:36 PM
  3. Last track day of the year
    By BLOWN38 in forum Racing/Track Results
    Last Post: 11-18-2008, 11:53 AM
  4. first hand wash of the year :) "ok pics workin"
    By 92sclikenew in forum Non Technical Forum
    Last Post: 03-12-2007, 11:38 PM
  5. OK, Here's the first Rallye of the year!!! This is cool!!!
    By lube70 in forum Super Coupe Club of New Jersey
    Last Post: 03-25-2002, 10:54 PM
