Page 1 of 5 12345 LastLast
Results 1 to 15 of 67
Thread: Parting out '90 SC & many performance parts
    Jul 2016
    Big Rapids, Michigan
    38
    I have a 90 Super Coupe that I have since decided to part out. I am keeping the engine and blower. Let me know what you need.
    I am really struggling with this decision because it's such a nice car. The under side of car has a lot of rot.
    Some performance parts for sale..
    Scorpion 1.7 Roller Rockers -- $170 shipped
    C&L 76mm mass air - I think its calibrated for the larger injectors. Not 100% sure though. The injectors on the car say F4xx for part number. -- SOLD
    BBK 70mm throttle body -- SOLD
    Comp Cams hardened pushrods -- $80 shipped
    Superchips Eliminator 6600 -- SOLD
    Supercharger -- SOLD
    I have these items listed on ebay as well.
    Jan 2015
    Tidewater area, Virginia
    229
    sorry
    that's a tough blow - very sorry. don't forget to thank the seller for hiding the rot.
    95 5spd Pearl White SC, "Millennium TBird" (erst Dr. Jekyll)
    95 Automatic Red SC
    Feb 2004
    IA
    4,252
    Where is the car located?
    Honor, Grace and Dignity......Remember these
    Sep 2015
    Connecticut
    223
    Yes where is it located?
    Jul 2016
    38
    Yes it is a tough blow. Overall, this car is in very good condition. My plan was to rebuild the engine and maybe repaint car. You don't see too many 5 speeds around.
    Sorry.. didnt realize my profile didnt show location. I have updated this. I live in Michigan. About an hour north of Grand Rapids.
    May 2013
    98
    Are you willing to ship items? I have a few things I could use if you will ship....
    Passenger side window motor and the passenger side door cup insert. If the motor is in good working condition and you can remove the cup insert without breaking any tabs.
    Passenger side door switch panel if it can be removed without damage.
    Passenger side passive restraint seat belt cover if in good shape. The part that slides back and forth. Actually, I might just have you pull the whole passive restraint track now that I think about it.
    The outer windshield trim at the top of the windshield if removed without damage. I am going to pull mine off and repaint it, but I want a good spare in case I screw it up.
    Body side moldings on both sides if they can be removed without damage (6 total pieces).
    That's all I can think of right now, but maybe more later.....
    Shipping would be to 62040.
    Oh, and sorry about the rot....
    Thanks,
    Tony
    Jul 2016
    38
    I have attached some pictures. Not sure if this is what you want. The one bezel piece as a broken tab at top. The windshield trim has the rubber piece at top missing and the black is all cracked up on it. I dont have all my sockets here to get the seat belt piece off car. I think its a 10mm. It appears to be fine though. Not sure how to take out the window motor. i do not have a battery so I would need to figure out how to run the windows up and down. I have shown the window armrest piece. It appears to be fine as well.
    The outer trim will need to be looked at more when its not raining out. One of the driver side nuts are rotten apart. I will need to see what I can do to take it off. Not sure about the rest though. the passenger side door has a dent/scuff in the trim.
    Aug 2004
    2,023
    can you get me the two front bolts from the parking brake handle?
    May 2013
    98
    Quote Originally Posted by ziggy75 View Post
    Crap.....I wish the door cup insert had all the tabs....but I may take it anyway since you went thru the trouble of pulling it off the car and the price is reasonable. The door switch panel looks okay, but it looks a little different on my car. I'll have to double check next week when I get out to see my car as I don't have it at home at the moment.
    The windshield trim you have pictured is fine as long as you can get it off without bending it up. I'll sand it all down and respray it. Do a search using the words windshield trim removal....that may yield results. I believe you can get them off by using a thin putty knife and a small pry bar tool.
    I'll need a working power window motor obviously. I can wait until you make sure it's working. Do a search using the words remove window motor. That should yield results.
    About the body trim/moldings.....I'm talking about the pieces that are located in the mid door area. Not the side skirts that you have pictured. There are 3 pieces on each side of the car. A small length of trim near the back of the front fender, a long strip that runs the length of the door located in the middle of the door, and a middle length piece that is located on the rear quarter panel. I need both sides. I believe members here have used fishing line and a "sawing" action to remove those pieces successfully. If you can get them off without breaking them or warping them, that would be great. Again, use search function on how to remove. And after you get them removed, make sure to store them in a flat position. In other words, try not to stand them on end or they can warp.
    I appreciate you taking the time to pull these items.
    I am not in a huge rush for these items, so I can wait until you get time to do it.
    Do you have a pay pal account?
    If you post two more times, we can start Private messaging each other so we aren't clogging up this thread with communications between us.
    Thanks,
    Tony
    Jul 2016
    38
    I will take a look at the motor when I have some time tomorrow. I didn't even think about the mid door trim. I will see what I can do. As for the door handle bezel, I was surprised that the tab was broke considering how well it fit onto the panel.
    May 2013
    98
    That sounds great.
    Thanks again.
    Jul 2016
    38
    Hey no problem. I will try to get those trim pieces off tomorrow. What I may do is attach these to a small strip of wood. That will keep them from warping.
    May 2013
    98
    That should do the trick. You can PM me with prices including shipping to 62040 if you want. If we keep this thread streamlined, you'll have an easier time keeping track of requested parts from others.
    The payment process seems to run very smoothly using pay pal if you have an account.
    Jul 2016
    38
    Bump............
    Sep 2015
    Connecticut
    223
    How are the upper and windshield cowls? Cracked, faded?
  1. Soon to part out 90 SC
    By Aaron Gott in forum Non Technical Forum
    Last Post: 10-02-2016, 10:18 AM
  2. Replies: 42
    Last Post: 12-15-2007, 11:51 AM
  3. parting out 90 sc everything must go
    By ZOOMBUGGY3 in forum Parts for Sale
    Last Post: 03-02-2005, 09:14 PM
  4. Parting out 90 SC
    By Ryan A Harris in forum Super Coupe Club of Ontario
    Last Post: 07-11-2004, 08:04 PM
  5. Parting Out 90 Sc
    By EGGZ_90 _SC in forum Super Coupe Club of Ontario
    Last Post: 05-27-2004, 05:48 PM
