Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
Thread: Stainless Steel Brake Line Kit Install...
  1. #16
    Oct 2003
    Allentown, PA
    908
    I purchased a set a few weeks ago and had the same issue with the 3-way block. I was told I had the last set. We ended up having to purchase a 3-way tee. We asked for instructions (see below). Other than that the installation went well.
    ----Forwarded Message-----
    >From: Mike McGraw
    >Sent: Sep 9, 2016 1:23 AM
    >To: Spinning Wheels-SC
    >Subject: Brake lines
    >Hello,
    >I have installed a set of these brake lines
    >on my 1990 super coupe. These brake line
    >work very well. When I installed my set
    >of brake lines, I put all the mounting brackets
    >the brake lines from the kit. You can do this
    >two ways, I removed all of my old brake line
    >brackets from the hoses. You have to grind the back side of the crimp that holds the brake brackets and just pry them off with a screw driver. I then mounted the brackets on the car install the hose so you can see where to put the bracket so you have even slack when you steer the font wheel right and left.
    >Holing the new bracket up to the old bracket. Mark the new bracket to the old.
    >Remove old and new bracket, lay the new bracket on the old one and weld them together. The other way would be to just mount the new bracket to the cars frame so that the brake lines have enough play and slack for proper movement.
    >If you have any questions with the installation of these brake lines please contact me at mikemcgraw64@yahoo.com
    >or (720) 585-1784
    >Thank you!
    >Mike McGraw
    J.Miller
    1990 XR7 and 1955 F250!
  2. #17
    Greenville, IN
    4,404
    Quote Originally Posted by TbirdTim View Post
    Hey Matt,
    What was the end result?
    Did you end up getting your stuff swapped out?
    Tim
    I got the missing tee, and finished the back brake lines this weekend. The tee looked just like the one I had sourced as a back-up....off Jeg's or Summit, etc.
    Matt Haub
  3. #18
    Greenville, IN
    4,404
    I ended up bending the bracket to mount closer to a factory configuration. This allowed be to get away with minimal line bending!
    Matt Haub
  4. #19
    20,990
    Matt,
    Just installed a set of these hoses a couple weeks ago at SCU inc. We had to bend the tab on the supplied fitting block 90 degrees before it would work on my 91 SC.
  5. #20
    Greenville, IN
    4,404
    Matt,
    How do you like the brakes now, David?
    Matt Haub
  6. #21
    20,990
    They feel about he same to me, but I've only done some mild braking since getting the stainless hoses installed. The brakes have never been very impressive or either of my SCs and even with the 13" Cobra front brakes they still feel kinda weak compared to the brakes on my 16 Expedition. That said, they are good enough for how I use the car.
  1. *SOLD* Stainless Steel Brake Lines
    By Mike8675309 in forum Parts for Sale
    Last Post: 10-19-2014, 03:09 PM
  2. Stainless Steel brake line set for 93 and up.
    By Flip in forum Parts for Sale
    Last Post: 02-14-2009, 08:33 PM
  3. Stainless Steel Brake Lines
    By DLF in forum Want to Buy
    Last Post: 01-11-2009, 03:50 AM
  4. Stainless Steel Brake Lines - Official GP!
    By Thomas A in forum Group Purchases / Specials
    Last Post: 11-17-2008, 07:01 PM
  5. stainless steel brake lines
    By L/F 93 man in forum Technical Forum
    Last Post: 06-08-2005, 05:56 PM
