Results 1 to 10 of 10
Thread: Replacing coolant reservoir
    Dec 2015
    Daytona Beach, FL
    220
    So on my way home from school today my car started overheating. So I pulled into O'Reillys and popped the hood. Thank god it wasn't something head gasket related, but there was coolant spilling everywhere, coming from a big crack in the upper part of the reservoir. I bought some gorilla tape and some radiator reservoir epoxy stuff and babied it home.
    I have since established that I'm going to be replacing it. Is there a special procedure that I have to go by or is it pretty straightforward?
    Thanks,
    Joe
    PNW
    6,402
    What year?
    I've never had any luck repairing these types of tanks.
    I have some spares for early models, but I think I've sold off the best looking ones so far.
    I might also have the fluid level sensor...long or short?
    Ken
    Jul 2005
    394
    Good afternoon
    I would not bother with it. The repair will have to endure repeated hot an cold coolant cycles. Plus over time the "crack" tends to extend past the repair area. Go to your nearest salvage yard for cougar and or thunderbird replacement unit. Inspect for cracks and clean the inside. Don't forget to get a few spare low coolant sensors if your recovery tank has one.
    Good Luck.
    Jul 2005
    Palos Heights
    2,294
    Tank
    Agreed..no luck fixing them......I have a good early (89' - 92') tank.
    Dec 2015
    Daytona Beach, FL
    220
    Quote Originally Posted by CougarXR/7 View Post
    So im going to replace it, but gorilla taped it temporarily. About to be hit by a hurricane so that takes priority xD. My question is that is it supposed to run hot with a leak in the reservoir? It doesn't leak anymore, and Its full of coolant, but it still runs hot after driving for like 15 minutes. I'm worried it's a blown HG. Any advice?
    Roanoke, Virginia
    3,200
    Quote Originally Posted by Roboplex View Post
    The factory temperature gauge is really worthless in regards of being accurate or giving an actual reading that has value. Does it smell hot or do you smell coolant?
    -Tim
    Current Collection
    1995 Thunderbird SC - Auto
    1994 Thunderbird SC - 5spd
    PNW
    6,402
    The coolant reservoir's job is to act as an expansion tank when the engine/coolant heats up. When the engine cools down, the level in the tank lowers as the coolant moves into the main system. This way the level in the closed system is constant and excess air is kept outside.
    The reservoir isn't pressurized and doesn't play a direct role in the normal operation of the cooling system otherwise.
    Was the cooling system opened? Did you bleed all the air out? Is the level in the tank fluctuating between HOT/COLD? is the hose from the radiator cap neck clear? Does the upper hose collapse when the engine cools down?
    If it's just a matter of making sure any air is bled out, then you might see the engine running a bit hot or the gauge acting strange. What indications do you that the engine is running hot? Done any other work to the cooling system lately? How long did it take to notice the tank was cracked and was the car driven around low on coolant?
    May 2012
    Oregon
    781
    I'd be worried about blowing a head gasket. Burping it via the service plug near the thermostat would be the first thing I'd do to it (before driving it again).
    Jul 2005
    Palos Heights
    2,294
    Bottle
    Were you able to find a good bottle? I have one from a 35 "Anni".
    Dec 2015
    Daytona Beach, FL
    220
    Haven't found one yet. Do you know if they were the same in the LX Thunderbirds? My junkyard has an LX, not an SC. Burped the radiator today, a lot of bubbles came up, but I haven't taken it on a drive yet. What's the price on the one you have?
  1. Need 94 coolant reservoir
    By IkeyM in forum Want to Buy
    Last Post: 10-05-2008, 05:28 PM
  2. 94-95 Coolant Reservoir
    By darkstar_one in forum Parts for Sale
    Last Post: 11-22-2006, 11:46 PM
  3. Replies: 4
    Last Post: 07-21-2006, 06:03 PM
  4. will this work as a Coolant Reservoir?
    By SC UL8R1990 in forum Technical Forum
    Last Post: 07-20-2006, 12:31 PM
  5. Relocated coolant reservoir (pics)
    By SC UL8R1990 in forum Non Technical Forum
    Last Post: 06-17-2004, 08:26 AM
