Results 1 to 7 of 7
Thread: Problem replacing stock front sway bar links
    Oct 2004
    Hudson, WI
    168
    I've removed the front left where I had a knock and that link sure has some play in it !!
    Problem is I'm replacing it with greaseable Moog links and they have a bend close to one end. The original ones are just straight. Does it matter if I install them with the bend closer to the top or bottom ??
    Similar to OEM link http://www.oreillyauto.com/site/c/de...2973&ppt=C0106
    Moog I'm installing http://www.oreillyauto.com/site/c/de...2973&ppt=C0106
    May 2004
    Va. Beach,Va.
    7,017
    I'm just installed Moog front sway bar end links and I put the bend at the top.
    SCCOA Member #2406
    '94 SC AUTO - 2.3 Whipple
    '90 SC AUTO - Bone Stock
    Pacific Rim
    6,701
    When I replaced the ones on my '90, they looked like this:
    You may have late model (kinked/S) links....?
    May 2004
    Va. Beach,Va.
    7,017
    Since both of his attached links are for a '95 supercoupe I figure that's what he has.
    SCCOA Member #2406
    Pacific Rim
    6,701
    Quote Originally Posted by nickleman60 View Post
    Good point, missed that, thanks - were the late model OEM fronts just straight, then?
    Oct 2004
    Hudson, WI
    168
    Yes, mine were just straight. That's what was causing me the confusion.
    Sorry about that. Now that I'm not a paying member I don't have a signature with the car. Yes, it's a '95 Supercoupe. Just couldn't justify paying $15 every year. Most forums have a lifetime option.
    Just finished up. Seems it's very handy having a C clamp to apply pressure on the top to keep the stud from turning. Clamped the back of the link to the spindle ?? Anyway, it jams it in there so it doesn't turn when you're trying to tighten down the nut. Used a hammer handle to hold the bottom one in.
    The passenger side was really loose and I fully understand the rattling and clunking that was driving me nuts.
    Next will be the sway bar bushings.
    Pacific Rim
    6,701
    That works - I usually side-load, and/or hand press the stem into the hole, then hit the nut with an air impact.
    Forgot to ask if your '95 is lowered?
    Thanks for the wrap up and good luck w/the bushings.
    Ken
  1. removal of front sway bar links? what tool is needed?
    By BArtkowsky in forum Technical Forum
    Last Post: 03-30-2008, 02:21 PM
  2. '93-'98 T'bird or Mk 8 front sway bar end links
    By jpmcdonald in forum Want to Buy
    Last Post: 01-28-2006, 12:25 PM
  3. Front sway bar end links for ADDCO bar
    By MN12nationals in forum Technical Forum
    Last Post: 09-04-2005, 01:46 AM
  4. Front sway bar end links
    By supercoupe92FL in forum Technical Forum
    Last Post: 01-13-2003, 06:28 PM
