Page 1 of 16 1234511 ... LastLast
Results 1 to 15 of 226
Thread: Winter upgrades for 2016
    Sep 2004
    Herrin Illinois
    3,412
    Well as alot of you know one of my headgasket's sprung a leak so I will be giving the motor a good refreshing as well as a few other things. I just recently replaced the valve springs but I am sending my cylinder heads to scui to have them converted to 7/16 stud mount, also having them pressure tested and the full work up. As far as the motor goes I pulled it out today and I am going to start disassembly tomorrow. I have had crank case pressure issues for a while now so hopefully freshening up the motor to remedy that. I am going to add a double roller timing set, high performance lifters and I am ditching the pcv system for moroso crank case breathers. While the motor is out I'm going to completely refinish the engine bay and paint it. I am also upgrading the stereo system to a more racing friendly setup and installing an aluminum wall behind the rear seat to make it nhra legal. I am also upgrading the drag wheels and tires to 17" skinnies and 15x8 welds with Hoosier 27" slicks. I will post pics as things progress.
    member #2488
    Sep 2004
    Herrin Illinois
    3,412
    so far so good
    well the motor is out and apart the bottom end looks good, no sign of headgasket/antifreeze damage. While its apart it will get new rings, cylinder hone, new bearings, cleaned and checked out thoroughly. I plan to add a double roller timing set and hp lifters internally and possibly have the cylinder heads converted to 7/16 stud mount.
    While the motor was out I painted and detailed the engine bay and prepared it to accept the motor because I have decided to make some more changes while its apart. I plan to add a new Kenne Bell 2.1 Big bore blower when it goes back together since the motor will be good and tight.
    I also have the full set of wheels and I am going to run 26.5 5.5 radials up front on 17 x 4.5 race star skinnies and 27 10.50 15 hoosier quick times out back.Name:  engine bay d.jpg
    Name:  engine bay d2.jpg
    Name:  engine bay d3.jpg
    Name:  engine bay d4.jpg
    Name:  engine bay d5.jpg
    member #2488
    Sep 2004
    Herrin Illinois
    3,412
    Name:  engine bay d6.jpg
Size:  226.4 KBName:  engine bay d7.jpg
Size:  247.7 KBName:  engine bay d8.jpg
Size:  161.5 KBName:  engine bay d9.jpg
Size:  192.1 KBName:  engine bay d10.jpg
    member #2488
    Sep 2004
    Herrin Illinois
    3,412
    Name:  engine bay d11.jpg
Size:  153.3 KBName:  engine bay d12.jpg
Size:  188.9 KBName:  engine bay front skinny.jpg
Size:  343.2 KBName:  race star.jpg
    member #2488
    Jun 2007
    Whitby On. Canada
    966
    Looks great, those wheels are killer.
    Drew
    Jul 2003
    Ottawa, Ohio
    5,407
    What did you use to clean the engine bay? Need to do the same before putting my motor back in.
    SCCoA Member#: 2515
    1990 SC AOD 2.1L Kenne Bell
    11.676 @ 121.35 mph
    506hp/478tq
    Sep 2004
    Herrin Illinois
    3,412
    I used a pressure washer and degreaser that I sell. Then I sanded it down with 320 and painted all the red with automotive color match e4 red and professional grade clear coat. I also cleaned up all the harnesses and insulated the harness and wiring on the driver side, I found the headers melted some of the looms.
    member #2488
    Sep 2004
    Herrin Illinois
    3,412
    Well update on the motor is not really good but not that bad either. It had vertical scratches in 3 of 6 cylinders but the scratches in #4 were more than .001 so I have decided to use a new block around the already perfect rotating assembly with new rings. The other block will be used at a later date for a 4.2. In other news while I'm fixing the motor I decided to go ahead and install a nice Shiney 2.1 kenne bell big bore.
    member #2488
    Atkinson, NH
    4,201
    If you have the ability, I'd recommend machining more backspace into those wheels. I was able to tuck them much better with a 2.375" backspace.
    Sep 2004
    Herrin Illinois
    3,412
    Quote Originally Posted by fastsc92 View Post
    Did you do yours or have them done
    member #2488
    Atkinson, NH
    4,201
    Quote Originally Posted by davec73 View Post
    I machined them. There is enough meat to even tuck them in further and still maintain caliper clearance. If i did it again i'd go 2.5" BS however I didn't want to fixture them up again. Once you bolt them up...the 1.75" BS sticks out a ton. You'll want to tuck it in if you can. I was using cobra brakes so your caliper clearances may vary but I had enough room to go 2.5" BS but machined them @ 2.375"
    http://www.sccoa.com/forums/showthre...82#post1098882
    Sep 2004
    Herrin Illinois
    3,412
    How much material would be removed for 2.5?
    member #2488
    Sep 2004
    Herrin Illinois
    3,412
    BTW what I really need right now is a tubular front k member ]
    member #2488
    Atkinson, NH
    4,201
    how much material would be removed for 2.5?
    1.75" + .75" = 2.5"
    1.75" + .625"= 2.375" :d
    Sep 2004
    Herrin Illinois
    3,412
    1.75" + .75" = 2.5"
    So you remove 3/4" wow.
    member #2488
  1. Winter Upgrades for 2016
    By davec73 in forum Non Technical Forum
    Last Post: 05-25-2016, 09:20 PM
  2. New upgrade for 2016!!!
    By neverfastenough in forum Non Technical Forum
    Last Post: 02-29-2016, 06:28 PM
  3. Winter upgrades for 2015 Stage 1 complete!!
    Last Post: 05-23-2015, 10:58 PM
  4. battery and alternator upgrades for 89SC
    By NJTBIRD89 in forum Technical Forum
    Last Post: 06-23-2003, 12:08 AM
  5. Winter tires for sale
    By Katoom in forum Super Coupe Club of Ontario
    Last Post: 10-22-2002, 04:17 AM
