David Neibert
SCCoA Admin
I bought a cord setup just like yours. I even wired it up. Havent used it yet. One of our smarter members here suggested using the cruse control button keeping both hands on the wheel. I was starting to wire the two step in but got side tracked trying to just get it up and running. Guess there time in the spring to do that as well. what do you set yours in relation to stall speed of your converter. I have a 3000 stall converter
Ken,
With a 3500 stall converter I had my two step rpms set at around 3000. Some people go higher than rated stall setting, just depends on what rpm and load you need to spool the turbos. Higher rpm usually means higher boost at launch. Here is a go-pro video of me using the trans brake and two step on my 93 SC..watch my right hand to see button released and dropped.
https://youtu.be/qGVSNJH5a3I
