Thread: Having some troubles with my 1996 Thunderbird 4.6
    Jan 2017
    1
    Hello from sweden! Having some trouble with my 1996 Thunderbird wich someone here might be able to help me with.
    Was out driving in around 50mph when it suddenly stalled, towed it to my work and swapped the battery out today.
    It runs perfectly when cold, but at soon as it gets a bit warm it stalls and does not have any idling at all.
    i have cleaned the air flow sensor, fuel pressure regulator works, fuel filter is new. I was reading online about the IAC being the fault, but can't seem to find it, if it even excists on this car.
    Running out of ideas here...
    Jun 2003
    Lexington Kentucky
    1,518
    Could be a coil issue after it gets hot.. I know on the SC's in the early years the DIS would get hot if the heat sink didn't cool and cause this issue. I know you have a 4.6 but it can be an issue along with plug wires arcing especially if they are on the exhaust manifold.... Just a thought if you don't get anything out of the Codes...
    Anthony Arnold
    Home of "No Cash Racing!"
    Silver 90 AOD 12.03 @ Shootout 2010
    White 94 Auto ??????
    Black 95 5-speed ????
    Jun 2011
    San Diego
    387
    did you get a check engine light? try to pull diagnostic codes. IAC "idle air controller" is the valve on the throttle body.
  1. trouble with my '90sc 5spd
    By 9552fred in forum Technical Forum
    Last Post: 03-30-2006, 12:23 AM
  2. Ate some rice with my ranger...haha!
    By 95lightningwnab in forum Racing/Track Results
    Last Post: 06-29-2005, 10:12 PM
  3. needed some help with my xr7
    By intercooled89xr in forum Super Coupe Club of New Jersey
    Last Post: 08-12-2004, 06:49 PM
  4. Craziest Chapter - let's have some fun with this
    By fred 4 pt 3 in forum Polls Forum
    Last Post: 01-12-2002, 04:18 PM
