Matt_aka_Dale
The better brakes are available for the 93+ spindles, and I know the slight difference between the 89+ and 93+, but is the bolt pattern still the same?
Actually the hub is not the same. The bolt pattern is the same, but the center bore is slightly different where the rotor sits on the hub. I think the later ones have the larger bore, so if you try to install the earlier rotors on the later hubs, they won't sit flush and it will warp the hell out of them, so when you swap the spindles, you will need to get some 93+ rotors as well.
