Results 1 to 7 of 7
Thread: My Braille battery finally died, so naturally my car got lighter
    Apr 2003
    Ventura, CA
    1,780
    Remember this little guy?
    It had a pretty good run: nearly 9 years, and that's decent by the standards of any battery, let alone one that small. I've actually been waiting on it to die for a while now so I could replace it with something lighter.
    I chose the Battery Tender BTL14A240C because I've been using one for the past two years in my LS1 Camaro and have been very impressed with it--no problems at all. I haven't taken any pics of it in the SC yet, but here's the one I put in my Camaro next to a PC680 for size reference:
    The Braille weighs 11 lb, 9 oz and has 220 CCA; the new battery weighs 1 lb, 12 oz, but has 240 CCA. And the lithium iron stuff is much safer than some of the older lithium batteries that were known for catching on fire.
    Jun 2008
    Columbia,SC
    623
    low price
    Seems really reasonable. Is this something you could dependably use in a dd? What do you do about the connections? I've never used anything but a stock battery, pretty ignorant about all things really.
    Apr 2003
    Ventura, CA
    1,780
    The connection was easy. Just get some posts like this:
    The new battery came with special rectangular nuts that go under the terminals. Just screw the posts into those nuts.
    As for daily use, they're not ideal. If all you do is start and drive, you'll be fine, but they don't have much reserve capacity. My IC fan comes on with the key on accessory, and I don't let it go for too long without the engine running. Whenever I use an AC compressor to air up my tires, I make sure the engine is running.
    I also like to leave the car on a battery tender if I'm not going to drive it for more than a few days. If you park on the street, that's not very practical.
    Apr 2003
    Ventura, CA
    1,780
    Picture:
    7,570
    Interesting stuff Will. I didn't realize that Battery Tender was also in the battery business!
    cheers
    Ed
    PNW
    6,515
    Quote Originally Posted by fast Ed View Post
    ...didn't realize that Battery Tender was also in the battery business!
    Batteries, Chargers, Solar, Wireless, etc.
    http://www.batterytender.com
    12V, 120 LCA Lithium Engine Start Battery
    Deltran Battery Tender's line of Lithium Iron Phosphate (LiFePO4) engine start batteries are designed to replace Flooded, AGM, and Gel cell lead acid batteries in Power Sport applications such as Motorcycles, ATVs, Personal Water Craft, Lawn Mowers, Utility Vehicles, Scooters, and Dirt Bikes.
    My Anny isn't my DD any longer, so I put one of BT's new computerized trickle charger/conditioners on it and it's worked great for months now.
    Greenville, IN
    4,314
    Man...that's tiny!
    Matt Haub
  1. My Mazda is finally fixed, *RANT*
    Last Post: 05-22-2004, 12:13 AM
  2. finally ran codes for my hesitation/backfire
    By beedogg91 in forum Technical Forum
    Last Post: 06-09-2003, 12:18 AM
  3. I found out why my 89 SC was making so much boost!
    Last Post: 04-27-2003, 10:59 PM
  4. Got my blower apart finally
    Last Post: 07-15-2002, 07:37 PM
