Results 1 to 9 of 9
Thread: Recently Purchased '89, Motor Needs Rebuilt?
    Jun 2017
    Ohio
    5
    Hi! 3 days ago I purchased my second Thunderbird, a 1989 Super Coupe. It appeared to have a vacuum leak. As it would heat up, it would begin to stall when I let in the clutch. Last night, I was driving and it began to make an awful noise, I will post a video of the noise, and on my way home, it began overheating. The coolant overflow tank was boiling. I let it sit over night. It is now back in my driveway and I have no clue what to do. I think that the noise is a rod bearing but am not exactly sure. Will it need rebuilt? Any input is greatly appreciated!
    Mike
    Jun 2017
    Ohio
    5
    1,536
    Yeah, that sounds like a rod bearing, and yes it means the motor will have to be rebuilt, or replaced. Replacing it with a good used one is likely your cheapest way out, but if you want to have it rebuilt, contact XR7Dave, as he is the go-to guy for engine work on these cars, and he is also in Ohio.
    407
    Quote Originally Posted by Kilo927 View Post
    Good afternoon
    Add cracked pistons/rings. Note at the 00.10 seconds the jet of smoke coming out of the oil service cap. Engine rebuild/replacement required.
    6,589
    Quote Originally Posted by sam jones View Post
    Looks like a lens flare....?
    6,589
    If you pull the dipstick, does it look like a milkshake? Same stuff in the overflow tank or radiator if you let it cool down and look inside?
    Damage is done, in any case - headgasket fail, most likely. Try not to fire it up again and open discussions with a reliable source for an overhaul or another engine.
    407
    Good evening
    You could also drain a little oil in a small container and stir with a screwdriver. If the oil has silver "metal flakes/sparkles" while stirring this would be a strong indication the bearing(s) are shot.
    Jun 2017
    Ohio
    5
    I drained the oil. It looks like used motor oil, except there are metal shavings in it. The radiator and reserve tank both look like a milkshake. The motor will need replaced. No clue what to do with the car now. Not sure if it's even worth it anymore.
    Thank you all for your help, I really appreciate it!
    Mike
    That stinks man good luck getting it rebuilt.
  1. beautiful 89 5S needs motor PA
    By blownbird2 in forum Cars for Sale
    Last Post: 03-27-2012, 12:11 PM
  2. 89 SC, need ideas for motor swap or rebuild?
    By repoman27 in forum Technical Forum
    Last Post: 06-22-2006, 09:19 PM
  3. Motor needed, for a friend
    Last Post: 11-13-2003, 09:45 PM
  4. 89 xr7 need help with u-joints
    By 89xr7man in forum Non Technical Forum
    Last Post: 05-06-2002, 11:45 AM
  5. Wiper Motor Needed
    By Distinguished Dat2k1 in forum Super Coupe Club of Ontario
    Last Post: 04-13-2002, 09:28 PM
