Results 1 to 10 of 10
Thread: 5 Speed Lower Shifter Boot
    Oct 2006
    Valparaiso, Indiana
    381
    Looking for the thick rubber boot that sits under the steel cover on the transmission tunnel.
    ny\long island
    2,692
    boot
    Quote Originally Posted by TBirdJKC View Post
    i think i have 1 from my 93-5-speed, i think it's att the the under side of the shifter......i think. when i took it apart a year ago i took the entire assebly.....i have to look tonite.
    Mar 2011
    SF, CA
    219
    If you can't find one in good enough condition and the goal is just to prevent odors coming up from your transmission tunnel, you can easily make one with a ziptie and some rubber inner tube material (obtainable from any tire shop that works on commercial tires).
    I have one on my tbird track car that works both as the "under boot seal" and as a replacement for the main leather boot (because I don't care what it looks like and someone offered to buy my upper boot off me).
    Oct 2006
    Valparaiso, Indiana
    381
    Quote Originally Posted by S4gunn View Post
    It's flexible enough to move with the shifter and stay attached to the floor?
    Mar 2011
    SF, CA
    219
    It all depends on how well you put it together.
    - I made the "flap" big enough to be held down by the metal plate and the bolts that hold the plate down (they go through the rubber sheet). I essentially made the sheet bigger than I needed and trimmed it to fit.
    - The hole for the shifter in the center is small enough that the shifter stub is held with tension by the rubber. A ziptie that goes over a small amount of the rubber sheet and around the metal shaft adds further security. You then flip the rubber sheet downwards so it's covering the ziptie and make sure there's enough slack so that the shifter can move.
    Since it's hard to imagine what I'm talking about, I took a few pics using some stand ins on my desk. Keep in mind that a rubber inner tube wont tear as easily as this tissue. You can also double up on the zipties to be extra paranoid.
    I don't care what it looks like and it seals well. Because racecar. For you, if you mount this low enough you will be able to put the stock shifter over it and you won't see it either.
Size:  134.3 KBName:  shifter2.jpg
Size:  146.4 KBName:  shifter3.jpg
Size:  155.5 KBName:  shifter4.jpg
    You can see it here. The button looking thing on top of the shifter was the push to talk button from my old comm system. My zipties are at the fat point of the shifter shaft (upon which a proper boot would probably rest). I think i redid it for aesthetic reasons (probably because I was bored and looking for projects ABOVE the fat section when I removed the PTT button). There's no reason why you couldn't attache your DIY lower boot lower down the shaft.
    ny\long island
    2,692
    rubber boot
    found it, let me know if u still want it.
    May 2012
    Denver Area
    809
    Do you know what time it is???? LOL - I love that clock in the center console
    Oct 2006
    Valparaiso, Indiana
    381
    Quote Originally Posted by pock1 View Post
    Definitely!
    Mar 2011
    SF, CA
    219
    I use this tbird for endurance racing. This was the easy solution to make sure drivers knew when to pit.
    Guaranteed visibility, requires very little change in focus from a driver compared to a digital dash clock, and (not that we need it) easy to see the time even if things get super shaky.
    You too could have one for $2 from IKEA.
    ny\long island
    2,692
    shifter boot
    Definitely!
    the boot is att to plate. i also found the shifter ~~~, and 2 other foam pieces. make offer. thx tony.the pics i took is not loading for some reason, i have to resize it. send me ur cell and i;ll txt it to ya.
  1. WTB - 5 speed shifter boot
    By RSC'91 in forum Want to Buy
    Last Post: 07-08-2014, 05:26 PM
  2. 94 - 95 leather 5 speed shifter boot
    By the-big-e in forum Parts for Sale
    Last Post: 09-30-2009, 10:13 AM
  3. 5 speed shifter boot
    By scbird1 in forum Technical Forum
    Last Post: 12-09-2004, 03:00 PM
  4. 5 Speed Shifter Boot
    By Tonyj in forum Technical Forum
    Last Post: 01-01-2003, 06:47 AM
