Results 1 to 5 of 5
Thread: Transmission Cross Member Bushings?
    May 2012
    Denver Area
    803
    Does anyone know where I can get transmission cross member bushings for our cars?
    PNW
    6,586
    If you mean crossmember-to-body - It's been a few years, but I failed to find new, so I ended up sourcing a pair of decent used, which worked out well, and along with a fresh tailshaft mount helped correct a slight twerk from the old ones that apparently suffered from aged motor mounts.
    May 2012
    Denver Area
    803
    Yes - cross member to body. When the rain goes away I'll be heading to my local wrecker from some goodies (dual piston Mustang brake calipers for one) and will likely be on the hunt for a 1997 bird in the hopes of some slightly fresher bushings.
    Aug 2004
    2,026
    It's been several years but, I got mine here.
    May 2012
    Denver Area
    803
    Oh yeah - found them there. A little steep but they might be worth it. Thanks Rick.
  1. Outer Cross Member Bushings
    By 90coug in forum Non Technical Forum
    Last Post: 07-05-2012, 05:45 PM
  2. Polyurethane Transmission Outer Cross Member Bushings
    By 90coug in forum Parts for Sale
    Last Post: 09-17-2010, 11:39 AM
  3. 94/95 Trans Cross Member / Poly Bushings
    By Dahoopd in forum Parts for Sale
    Last Post: 09-22-2008, 09:32 PM
  4. Polyurethane Transmission Cross Member Bushings NEW!
    By bman1985 in forum Parts for Sale
    Last Post: 09-18-2006, 10:42 PM
  5. Transmission Cross Member...
    Last Post: 06-04-2006, 02:34 PM
