Results 1 to 15 of 21
Thread: Sucking sound from gas tank
    Feb 2016
    Cincinnati, OH
    148
    The noise happens every once in awhile but usually is heard when car is in the 'on' position and fuel level is lower than 1/2. Also can smell gas. When the fuel pump was done, I did put a new o-ring on, so hopefully that's not the cause of the smell.
    Any thoughts?
    PNW
    6,590
    Quote Originally Posted by Matt_aka_Dale View Post
    Do you hear a sucking sound when removing the gas cap after a drive?
    Feb 2016
    Cincinnati, OH
    148
    I don't hear it from the gas cap after a drive. Maybe I should revisit the fuel pump and whatnot.
    PNW
    6,590
    Can you say if the gas smell is worse at the front or the rear of the car?
    Any work you know of done to the vapor recovery tank/system inside the right front fender near the air snorkel?
    Any codes thrown?
    Feb 2016
    Cincinnati, OH
    148
    No known codes. I doubt anyone has messed with the canister and lines.
    The gas smell is well know from the rear. When i'm driving, sometimes I can smell it when the sunroof is open.
    PNW
    6,590
    No fuel drips on the ground when parked?
    Checked the plastic lines for leaks/splits near the fuel filter, back to the tank?
    Happening when less than 1/2 full sounds like a vapor issue vs. raw leak, maybe. If it were raw and around the pump, it should be worse when full, I'd think.
    Could be anywhere in the system if it's vapor...
    Pull the vacuum line off the fuel regulator and see if it's wet.
    How long ago was the pump done?
    Have any trouble then reconnecting the filler and vent lines at the tank?
    Oct 2006
    Valparaiso, Indiana
    378
    It's somewhat common for the short, soft, rubber line that connects the nylon vapor return line to the metal line coming off of the hat, to dry-rot and split.
    Norcross, GA
    3,314
    Check the cross over hose at the rear of the tank. It's above drive loop. I've seen those crack and have loose or broken clamps.
    Feb 2016
    Cincinnati, OH
    148
    Found the leak
    Guess the plastic pressure line finally gave out. Now what?
    PNW
    6,590
    I don't think the OEM hard lines are still available, which may be why that non-OE stuff is already there...ouch.
    Time to splice/repair properly - be sure to check how much of the line has failed. Repairs depend on if you splice or replace - example solutions: http://www.oreillyauto.com/site/c/se...1652/C0290.oap
    Mar 2010
    Grafton, OHIO
    647
    Hey Matt,
    Welcome to the heart of the rust belt! I'm up north of you in Cleveland, GO CAVS!
    But seriously, I'm suprized the plastic lines failed. Any evidence that they were hit or pinched by road debris or jack/stands? I've repaired 3 or 4 STEEL lines ( rustbelt joke^), and in fact have a hoopty in need of the repair now As KMT pointed out the repair stuff is ava, and pretty easy. I pick it up at my local Federated store, I believe S,U,R&R is the name of company marketing it. It has 2 styles of fitting, a VERY easy to work with compression splice that is removeable/reusable, and a barbed nipple that is a little less so. It requires a clamp like press tool that the store may or may not loan, I would NOT try this style without the tool. They say just soak line in hot water then press in. I don't buy that. The compression couplers r great and I've never had a problem with them. Just make sure you inspect and find the best place to remove any and all damage.
    Good luck
    Adam
    PNW
    6,590
    Heat gun works wonders in those examples...
    Feb 2016
    Cincinnati, OH
    148
    As usual, this forum is top notch. Appreciate the help guys. Just love the 'fix one thing and something else breaks' curse
    PNW
    6,590
    Quote Originally Posted by aroot1 View Post
    I've had less than positive results w/the white tubing when exposed to fuel and heat over time. I don't recommend it for anything but water, air/vacuum and sheathing for wire bundles.
    Mar 2010
    Grafton, OHIO
    647
    Never seen the white stuff. I was getting black, supposed to b designed 4 fuel. Have access to a real "slippery" feeling blue hose at work used 4 industrial air, but was un able to find anything about fuel exposure. Decided THAT was a bad idea . The couplings however were the very same as parts store stuff
    Adam
  1. Replies: 6
    Last Post: 04-01-2010, 05:16 PM
  2. Humming from the gas tank
    By 92SCDoughboy in forum Technical Forum
    Last Post: 02-06-2003, 06:11 PM
  3. 94 & up style gas tank
    By 89sc in forum Technical Forum
    Last Post: 07-30-2002, 10:01 PM
  4. exhaust on a sc with an early model gas tank.
    By Kick Ass Kolenc in forum Super Coupe Club of Western Canada
    Last Post: 04-01-2002, 03:06 AM
  5. free gas tank
    By awoo in forum Super Coupe Club of Northern California
    Last Post: 01-27-2002, 06:57 PM
