Page 4 of 9 FirstFirst 12345678 ... LastLast
Results 46 to 60 of 121
Thread: Brakes
  1. #46
    Pacific Rim
    6,701
    Quote Originally Posted by smac View Post
    Which would mean the pressure switch is not faulty?.
    If you ground pin 4 at the pressure switch connector and the pump runs, the relay is good, the pump is ok, and the pressure switch is suspect as failed.
  2. #47
    Jan 2016
    95
    Alright! This weekend's project: ground pin four of the pressure switch connector. I'll let y'all know...
  3. #48
    Dallas, TX
    5,705
    Note.. Its really tucked in there. You need "E.T." fingers to accomplish this task..
    It might be easier to unplug the connector from underneath the car, and then insert your grounding wire from top side.
  4. #49
    Pacific Rim
    6,701
    Agreed and good idea.
    I find that removing the ARC shroud helps the overall process. First time is difficult, but like so many things on an SC, it's near trivial once you've been around the tree before. The hard part is not breaking the clips on the decades old connector
    I'd go after the ignition switch before I'd debug the pressure switch, BTW.
  5. #50
    Dallas, TX
    5,705
    I did test the connector the relay plugs into, and it read 10v DC. So this would mean that there is power getting to the relay?
    10v DC usually means a loose/frayed/broken wire or a loose/dirty connector spades. Wiggle and push the test leads around fishing for 12V (battery voltage). It also could be a loose fuse, a loose ignition switch, corrosion on electrical contacts, etc..
    most of the time, thats SORT OF (not always) what low voltage is telling you.
  6. #51
    Pacific Rim
    6,701
    10v DC at pump relay (for what it's worth)
    How many at the battery?
    The SC loves 11.2 or more, so...
  7. #52
    Jan 2016
    95
    Went out last night and wiggled the ignition switch and bingo. Problem solved. Played around some more this morning; pumping brakes, etc., same results. So... buy a new one and install it? Or leave the steering column covers off and wiggle the thing every time I have an electrical issue and hope it solves it?
    Also: I noticed that there is a wire hanging loose with part of a broken connector on it, and the other part looks to be fixed to the ignition itself, on the side facing the driver. The broken edges all line up, but the wire doesn't completely reach the ignition and the rest of the connector there. Thoughts? I'll try to post a picture when I get home.
  8. #53
    Pacific Rim
    6,701
    These switches don't last forever, they are readily available, aren't that expensive, and not that hard to replace...you will need the proper torx, tho.
    I'd treat the car to a new one in any case.
    Will wait for the photo on the wire, but it might help narrow things down if you can say how thick and what color, thanks.
    Or trade it for mule and shoot the mule...
  9. #54
    Dallas, TX
    5,705
    Eliminate the known headache and replace it.
  10. #55
    Jan 2016
    95
    This is the only one I could get to upload (yes, I tried to upload the from my phone).
    You can see the wire, just your sorta standard 16g automotive wire, gray with a red stripe, and it looks like it, at one point, butted into the fractured connector in the ignition.
  11. #56
    Pacific Rim
    6,701
    Ah, yes, that's the contact that tells the chime if you leave the key in and open the door.
    I had to source one off a donor at the wrecking yard. As I recall, you need to remove the lock cylinder to slide it out to the right...other end is obvious, I think. To remove the lock cylinder, insert the key, rotate to 'on', then look underneath for a small round ball - push in on it, then slide the entire assembly out to the right.
  12. #57
    Jan 2016
    95
    Well, we're back in business! Got the new switch, took a little drive, smoked several of the local rods, and all is well so far.
    I declined to repair the chime wire for now.it now makes sense that I never heard the chime when the key was still in and I opened the door. Perhaps when I have more time...but then there'll probably be something else! When something else comes up (let's face it, it's an aging car; things will break), I will return, and hopefully in a new thread about a different issue! I'm a little tired of seeing that abs light, though I'll admit I have gained a ton of knowledge from this little issue.
    Thanks again, folks!
    Here's a photo of the car itself, just for kicks.
  13. #58
    Pacific Rim
    6,701
    Glad you sorted out, thanks for the update and good luck.
    Ken
  14. #59
    Nov 2016
    PNW
    287
    +1 one on success with getting it fixed. Darn clean car. Don't need no stinking chimes :-).
    Creighton
  15. #60
    Dallas, TX
    5,705
    Looks good.
    My chime module somehow unplugged itself a couple years ago.. I run the risk of leaving the lights on, but at least it doesn't annoy me with complaints about the seat belts and I can play the stereo with the doors open now.
  1. Clutch Master Cylinder/Brake Master Cylinder failure?
    Last Post: 06-06-2002, 01:24 PM
  2. Sean..........Brakes?
    By ryan a harris in forum Super Coupe Club of Ontario
    Last Post: 06-04-2002, 11:43 PM
  3. Brake Rotor Problem
    By Seshead in forum Super Coupe Club of Ontario
    Last Post: 05-15-2002, 11:37 AM
  4. Antilock Brake Driveway Test?
    Last Post: 04-30-2002, 10:40 AM
  5. Brake Fluid Resevior? Anyone have one
    By BlueThunder90 in forum Super Coupe Club of Ontario
    Last Post: 02-06-2002, 10:38 PM
