Results 1 to 11 of 11
Thread: Spindle swap question
    Feb 2016
    Cincinnati, OH
    137
    What do I need to do here.
    I'm in the process of doing the spindle swap and I noticed something. The newer spindles don't have the same abs connectors as the stock abs. Two different style abs sensors.
    Should I cut the connectors and splice the correct ones on or try something else?
    Feb 2003
    Tinton Falls, NJ
    1,508
    Either swap the connectors, or swap the whole sensor.
    Dallas, TX
    5,660
    Quote Originally Posted by Matt_aka_Dale View Post
    I tried to remove the old sensors first, but they didn't survive the operation.. So I spliced the connectors on instead.. Worked just fine.
    Feb 2016
    Cincinnati, OH
    137
    Alrighty I'll give it a shot. Fortunately I have great soldering skills.
    PNW
    6,402
    Vs. crimping, good on you. Be sure to also seal properly - nothing like moisture and corrosion in the wiring to foul ABS sensor accuracy. I'm chasing that issue now on another Ford product, and the TSB recommends replacing the sensor, which by default insures a fresh connector, at least on that side of the circuit. Symptom is a random ABS light, with no loss of braking function, that goes away with a restart. The poor ABS computer must get confused easily
    BTW, it is possible to adapt a newer style sensor harness, but it seems a pain to go that far given how hard it is to reach the other connection on the body.
    Feb 2016
    Cincinnati, OH
    137
    Setback after setback
    Once again, I've hit a snag.
    1. The shims on the caliper bracket are rubbing on the rotor. Which could be a possible easy fix.
    2. The rotors don't fit well against the center of the hub. I can hold it on with the lug nuts, but it is out-of-round.
    As far as I know, the spindles and hubs are '93.
    Jul 2005
    394
    Good morning
    Make sure the hub is matched to the year specific rotor. http://www.sccoa.com/forums/showthre...C-front-rotors
    I know you need the 1993 larger spindle to install the larger rotors but stranger things have happened. Like not taking in account of the hub assembly.
    I ran into this problem with a 1991 SC. The drive side rotor and hub matched but the passenger did not. It had a 1990 hub with a 1991 rotor. At that time I was unaware of the differences.
    The unbalance not only snapped the wheel studs/lug nuts but "chewed up" the wheel stud holes something badly. Hard lesson learned. Check you wheel holes immediately and professionally repair them if necessary.
    Good Luck.
    Feb 2016
    Cincinnati, OH
    137
    So how do I go about finding out if it's the wrong hubs or wrong rotors?
    PNW
    6,402
    Find a website that sells rotors and shows measurements/specs. Take notes and confirm the ones you buy/install match. They may look the same, but the height of the hat and position of the rotor may not match your install.
    Feb 2016
    Cincinnati, OH
    137
    SCP has the KVR rotors for the '93 spindle/PBR setup. I'll ask Bill.
    Feb 2016
    Cincinnati, OH
    137
    Back to the brakes
    Well looks like it's time to replace the accumulator.
    Why? Well every time I press the pedal, the pump kicks on. If I press it light, no lights come on. But if I press it quickly, the brake lights come on until the pressure is back up. Yes, I have bled the brakes multiple times. After a quick search through the forum, I found my answer. "A bad accumulator will cause the pump to cycle every time the brakes are applied resulting in pump failure due to overheating."-LJGriggs
  1. Quick question on 93 SC spindle swap on my 89SC...
    Last Post: 12-15-2010, 12:23 PM
  2. New question for spindle swap
    By TinManSC92 in forum Technical Forum
    Last Post: 10-04-2010, 10:32 PM
  3. Another 93 spindle swap to 89 SC question...
    Last Post: 05-24-2010, 06:55 AM
  4. Spindle Swap - ABS Speed sensor question
    By Doug Williams in forum Technical Forum
    Last Post: 09-12-2008, 08:12 PM
  5. 93 spindle and PBR caliper swap questions
    Last Post: 07-18-2005, 04:48 PM
