Results 1 to 2 of 2
Thread: ECM replacement.
    Oct 2006
    Osage, IA
    187
    ECM replacement.
    Pretty sure my ecm went out. The number on mine says: F0SF-12A650-L2B. Which is the right one? I see there is an LB, but not an L2B. http://www.rockauto.com/en/catalog/f...computer),2896
    Apr 2007
    New Orleans, LA
    1,957
    the part number is useless, the hardware code and the catch code are the import numbers to go by
  1. PCM/ECM replacement?
    By SCandelous95 in forum Technical Forum
    Last Post: 09-17-2007, 11:00 AM
  2. Upper Control Arm replacement.
    Last Post: 06-06-2002, 07:18 PM
  3. Rear Diff pinion seal replace or good mechanic in east GTA
    By tmnsheppard in forum Super Coupe Club of Ontario
    Last Post: 05-31-2002, 03:44 AM
  4. How hard to replace this, and commoness?
    By Tazer999 in forum Non Technical Forum
    Last Post: 05-24-2002, 01:21 AM
  5. What needs to be replaced when installing new springs?
    By Seshead in forum Super Coupe Club of Ontario
    Last Post: 05-22-2002, 04:14 PM
