Page 1 of 3 123 LastLast
Results 1 to 15 of 38
Thread: Engine bucking issue
    May 2004
    Marlton, NJ
    136
    Car starts fine: when you accelerate gradually it's fine. But when you hit the throttle to accelerate and it kicks down it bucks violently until you take your foot off . It did it once or twice in the beginning. Now it's all the time. Replaced fuel pressure regulator. No affect. Also, no codes or check engine light on. Ideas????
    1990 X7 auto
    PNW
    6,375
    Done anything w/plugs and wires lately?
    Done any engine cleaning recently?
    See any evidence of rodent nesting?
    How old is the fuel?
    Checked the harmonic balancer?
    May 2004
    Marlton, NJ
    136
    Nothing with plugs or wires
    No animals
    No eng clean
    Dampner is ok
    May 2004
    Marlton, NJ
    136
    Fuel is new
    PNW
    6,375
    Does the tach jump around?
    How many miles on plugs/wires?
    Any mods?
    Manual or auto trans?
    May 2004
    Marlton, NJ
    136
    Tach jumps until you take foot off throttle
    6k on plugs and wires
    May 2004
    Marlton, NJ
    136
    No modifications
    May 2004
    Marlton, NJ
    136
    Auto trans
    PNW
    6,375
    Most times w/these cars, plug wires are the issue when you see heavy miss/bucking.
    I'd go over them carefully to be sure they're still fully seated - as hard as that can be to do.
    Might want to search here on tach jumping, just to be familiar w/that issue and it's causes.
    May 2004
    Marlton, NJ
    136
    I'll check k them. Thanks
    Dallas, TX
    5,654
    I'd vote for plug wires.. not seated fully.
    But something else you can do is to disconnect the cam sensor. See if that clears it up. Takes multiple tries to start the car, but once its running it will run fine. If the problem goes away, replace the cam sensor.
    May 2004
    Marlton, NJ
    136
    I'll try that also
    Apr 2007
    New Orleans, LA
    1,957
    sounds like my original 90 sc I got from jersey back in 08, the problem on mine was that one of the plug wires was melted by the exhaust and the coil was on its way
    replaced both and it ran perfect, up until the crank split
    May 2004
    Marlton, NJ
    136
    Wires
    Any particular brand of wires you recommend?
    Oct 2012
    34
    Plugs and wires
    Thanks millions guys. New plugs and wires did the trick. Runs great!
  1. Bucking issues
    By Tony8470 in forum Technical Forum
    Last Post: 11-17-2010, 07:40 PM
  2. New Engine, Breakin Issues, Please Help
    By TheAWK in forum Technical Forum
    Last Post: 04-14-2010, 10:31 PM
  3. Engine Bucking/Tach Dropping
    By QuickMustang in forum Technical Forum
    Last Post: 02-16-2009, 12:17 AM
  4. 90 engine into 93 body, any issues?
    By Boostman23 in forum Technical Forum
    Last Post: 07-22-2002, 09:29 AM
